Internal Server Error - UNIX CGI - But not PHP MapScript
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Wed Dec 15 11:59:40 EST 2004
I just want to qualify. when I say the CGI core dumped I refering to CGI
apps in general not mapserv. mapserv rarely core dumps.
-----Original Message-----
[mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Ethan Alpert
Sent: Wednesday, December 15, 2004 9:57 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] Internal Server Error - UNIX
Can you/have you done an ldd on the mapserv executable? Does it
run at the command live with mapserv -v ? I susspect that mapserv is
missing a shared object. It may be possible that your shell environment
has a proper LD_LIBRARY_PATH but your webserver doesn't. Do your httpd
error logs have any additional info? My experience is that the error log
will just have an "ended prematurely" error in the case of the library
path problem. Most of the time when you get a 500 error I find that the
CGI core dumped.
-e
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bob Bruce -
Programmer
Sent: Tuesday, December 14, 2004 10:52 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Internal Server Error -
My hosting provider has tried to set up MapServer on a
UNIX server but we have run into this problem. I can run the the PHP
MapScript MapServerRecipe examples fine but when I try to run the
MapServer CGI I get this problem. I tried to run the Itasca workshop
example and it gave this "Internal Server Error" so then I tried to run
the most basic case of the the CGI in mode=map and it still gave this
error.
The strange thing is that I used exactly the same map
with the first PHP Mapscript MapServerRecipe example and it worked
great. After reviewing similar error reports in the Listserv I cannot
come up with a solution, so I'm asking for help from somebody out there.
My url to attempt to generate the most simple mode=map
image is:
http://murals.bighostbox.com/cgi-bin/mapserv?map=/home/m/murals/html/Map
ServerRecipes/hello.map&map_web_imagepath=/home/m/murals/html/tmp/&map_w
eb_imageurl=/tmp/&mode=map
(when I send the same URL on my Windows server, with the
directory names changed for the Windows system, it displays the image
properly, which leads me to believe that the map file is OK)
however when I run the php script that uses this same
map file:
http://murals.bighostbox.com/MapServerRecipes/hello.phtml
it works OK. The world protection on my html directory
is: r-x , the world protection on my cgi-bin directory is: r-x and the
world protection on the mapserv CGI file in this directory is: r-x. The
world protection on the tmp directory where the map image files are
stored is: rwx. So I'm assuming that the protections are set up OK.
When I run phpinfo() (which you can see by going to:
http://murals.bighostbox.com), I get:
MapServer Version MapServer version 4.4.0
OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=SHAPEFILE
PHP MapScript Version ($Revision: 1.220 $ $Date:
2004/11/16 17:23:13 $)
The map file is:
MAP
NAME HELLO
STATUS ON
EXTENT 0 0 4000 3000
SIZE 400 300
# IMAGECOLOR 200 255 255
IMAGECOLOR 255 0 0
IMAGETYPE GIF
WEB
IMAGEPATH "/home/m/murals/html/tmp/"
IMAGEURL "/tmp/"
# IMAGEPATH "/var/www/html/tmp/"
# IMAGEURL "/tmp/"
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
200 150
END
TEXT 'Hello world. Mapserver rocks.'
END
CLASS
LABEL
TYPE BITMAP
COLOR 0 0 0
END
END
END
END
thanks, in advance, for your help,
Bob
Bruce
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041215/af06fcfb/attachment.html
