projection problem
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Wed Dec 15 14:51:44 EST 2004
Looks like you have units meters and the data has units feet.
Also is there NAD support in your version of libproj4? I seem to recal
there are legality problems wrt distribution of NAD support in libproj4
and you need to dowload it separately.
You may also want to look up the EPSG code for your projection and try
that rather than the proj parameters.
-e
-----Original Message-----
Sent: Wednesday, December 15, 2004 12:49 PM
To: Ethan Alpert
Subject: Re: [UMN_MAPSERVER-USERS] projection problem
Yeah, I've given that a shot as well, but no luck!
Thanks though,
-Camden Daily
On Wed, 15 Dec 2004 12:46:23 -0700, Ethan Alpert
<ealpert at digitalglobe.com> wrote:
> Have you tried putting the projection BLOCK in the MAP block rather
> than the LAYER?
> -e
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On Behalf Of Camden Daily
> Sent: Wednesday, December 15, 2004 12:11 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] projection problem
> Hi all. I'm working on a mapserver application, and running into
> issues with projections. I have absolutely no background in GIS, but
> I've managed to hack together a pretty good map application using
> tiger/line data, which I believe is in latlong format.
> However, I have a new shapefile I've grabbed for the mass transit in
> my city, and it's in a completely different projection, and I have no
> idea how to get it to work in mapserver.
> When I run ogrinfo on my new shapefile I get the following:
> INFO: Open of `CTA_Line.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: CTA_Line
> Geometry: Line String
> Feature Count: 186
> Extent: (1101584.450000, 1841973.900000) - (1186739.850000,
> 1969991.020000) Layer SRS WKT:
> PROJCS["NAD_1983_StatePlane_Illinois_East_FIPS_1201_Feet",
> GEOGCS["GCS_North_American_1983",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",984250.0],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",-88.33333333333333],
> PARAMETER["Scale_Factor",0.999975],
> PARAMETER["Latitude_Of_Origin",36.66666666666666],
> UNIT["Foot_US",0.3048006096012192]]
> CTALINE_ID: Integer (11.0)
> ROUTE: String (50.0)
> COLOR: String (7.0)
> SHAPE_LEN: Real (19.11)
> SHAPE_FID: Integer (9.0)
> For my mapfile, I'm using:
> MAP
> NAME Chicago
> STATUS ON
> DEBUG ON
> SIZE 300 300
> IMAGETYPE PNG
> IMAGECOLOR 240 240 240
> SHAPEPATH "/web_system/data"
> FONTSET "/web_system/fonts/fonts.list"
> EXTENT 1101584.450000 1841973.900000 1186739.850000 1969991.020000
> UNITS METERS
> WEB
> LOG "/web_system/logs/mapserver.log"
> IMAGEPATH "/web_system/tmp/"
> IMAGEURL "/tmp/"
> END
> LAYER
> NAME "cta_line"
> TYPE LINE
> STATUS ON
> DEBUG ON
> DATA "CTA_Line"
> CLASS
> COLOR 0 0 0
> END
> PROJECTION
> "proj=tmerc"
> "lat_0=36.666666"
> "lon_0=-83.333333"
> "x_0=984250.0"
> "y_0=0.0"
> "k=0.999975"
> "ellps=GRS80"
> "datum=NAD83"
> "to_meter=0.3048006096"
> "no_defs"
> END
> END
> END
> Of course, no matter how hard I try, my map always comes up blank. If
> anyone can see anything obvious I'm doing wrong, or can point me in
> the right direction with how to debug projection issues, I'd greatly
> appreciate it.
> -Camden Daily
