Projection/Extent help
Camden Daily
cdaily at GMAIL.COM
Thu Dec 16 11:29:41 EST 2004
Hello all. I'm a mapserver newbie trying to figure something out.
Basically, I have two sets of shapefiles in different projections and
units. One has units of dd, and one has units of feet.
When I combine the two, I'd like to define my extents for the whole
.map file using dd instead of feet. I've made up a sample .map file
where I'm simply trying to display one layer with units of feet while
defining the extent using dd. However, everything I try just gives me
a blank page.
If I define the extent in terms of feet and drop the "proj=latlong"
line, it shows up fine. But I just can't get it to work when I define
the extent in dd.
Any help would be much appreciated!
-Camden Daily
MAP
NAME Chicago
STATUS ON
DEBUG ON
SIZE 300 300
IMAGETYPE PNG
IMAGECOLOR 240 240 240
SHAPEPATH "/web_system/data"
FONTSET "/web_system/fonts/fonts.list"
EXTENT -87.74 41.80 -87.56 41.98
UNITS DD
PROJECTION
"proj=latlong"
END
#EXTENT 1101584.450000 1841973.900000 1186739.850000 1969991.020000
#UNITS FEET
WEB
LOG "/web_system/logs/mapserver.log"
IMAGEPATH "/web_system/tmp/"
IMAGEURL "/tmp/"
END
LAYER
NAME "cta_line"
TYPE LINE
STATUS DEFAULT
DEBUG ON
DATA "CTA_Line"
CLASS
COLOR 0 0 0
END
PROJECTION
"init=epsg:26971"
END
UNITS FEET
END
END
