grids
Bart van den Eijnden bartvde at XS4ALL.NL
Fri Dec 17 05:45:32 EST 2004
the GRID keyword is not for displaying grid data, it is for adding a
graticule to your map.
If you want to display ESRI grid files, you will want to display them
through GDAL, so make sure GDAL support is compiled in.
E.g.:
LAYER
 DATA "ahn_100\geogegevens\landsdekkend\ahn_100\w001001.adf"
 TYPE RASTER
Btw, what type of Arcview grid do you have? Look here to see if your
format is supported:
http://gdal.maptools.org/formats_list.html
Hope this helps.
Best regards,
Bart
> Hello,
> I'm new to mapserver. I want to use grids in my application.
> The helpfile of mapserver (http://mapserver.gis.umn.edu/doc44/mapfile-
> reference.html#grid) doesn't help me.
> I have an arcview grid. The DATA field is empty, why.
> Thanks in advance
