pdf troubles
Francesco Sozzi
fsozzi at INTERCAD.CH
Fri Dec 17 12:02:39 EST 2004
Hi all,
I'm trying to write map on pdf by use of pdflib.
My code is:
<?php
dl('php_mapscript_44.dll');
dl('php_pdf.dll');
//require 'scripts/ic_php_globals.inc';
$gMapPath="C:/App/MapServer/tutorial/php/Locarno/";
$gMapFile="main.map";
$gHost=http://192.168.1.25;
//create image and URL
$gMap = ms_newMapObj($gMapPath.$gMapFile);
$gMap->setSize(1200,1200);
$gImage=$gMap->draw();
$gImageUrl=$gHost.$gImage->saveWebImage('MS_PNG', 0, 0, 0);
$gPdf = pdf_new();
echo $gImageUrl;
pdf_open_image_file($gPdf, "png", $gImageUrl);
What I get is:
http://192.168.1.25/MapServer/tmp/110330218632641.png
Warning: Internal PDFlib warning: [1910] PDF_open_image_file: Tried to
allocate 0 or negative number of bytes in function pdf_grow_images in
C:\App\MapServer\tutorial\php\locarno\pdf.php on line 16
Fatal error: PDFlib error: [2100] PDF_open_image_file: Function must not be
called in 'object' scope in C:\App\MapServer\tutorial\php\locarno\pdf.php on
line 16
Please note that:
- the URL is right
- I'm using mapserver 4.4 on Windows XP/IIS
Anybody has some suggestions?...
Best regards
Francesco
