OGR postgresql empty query makes mapserver fail
Paco Regodon mapserver at METEOLOGICA.ES
Mon Dec 20 12:35:52 EST 2004
Hello,
i hace created an OGR layer to connect to a postgresql layer in order to query
for some data. All works fine except that if no data is available, mapservers
doesn't generate an empty map. Instead, i get this error:
msDrawMap(): Image handling error. Failed to draw layer named 'OBSRAYOS'.
msOGRFileOpen(): OGR error. Open failed for OGR connection ` PG:dbname=obs
user=obs select x, y, from observations where obs_date between '20041216
00:00:00' and '20041216 11:59:59' WGS84 wkbPoint '. File not found or
unsupported format.
How can i do to avoid this error and get an empty map?
Paco Regodón
Meteologica S.A.
tel. +34.914561001
fax. +34.914561002
