Problem with mapserv 4.4 in Windows XP - IIS
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Tue Dec 21 02:20:48 EST 2004
When you run it from the command prompt, mapserv will automatically find the DLL and use it (based on your paths). However, when IIS 6.0 runs the mapserv.exe executable, there are limits from where a program is allowed to run from. I thought this applied only to .exe files, but maybe it applies to DLL's too....
Maybe you can try adding your directory with DLL's to the list of directories allowed to run programs (IIS configuration).
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Francesco Sozzi
Sent: 21 December 2004 15:16
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Problem with mapserv 4.4 in Windows XP - IIS
Hi all,
this happened to me testing 4.4 binaries with Oracle Spatial enabled. I've
made tests on four different pc (all Windows XP and IIS), and I've found
that in one PC (in the other it is ok) I had to put oci.dll (Oracle Class
Interface, required by mapserver with Oracle Spatial option) into the same
folder of mapserver dll. Note that oci.dll originally stays into folder
specified into PATH (<oracle root>\bin) and that "mapserv.exe - v" works
fine also without this workaround; but to run into browser I had to move
this dll. Strange...
Please note that I install MapServer by putting all required dll into a
dedicated folder (<mapserver root>\lib) and by specifying this path into
PATH system variable.
Regards
Francesco
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, December 20, 2004 11:17 PM
IIS
> Hi Harold,
> I just tried IIS and I get that exact error if I don't have all of the
> required dlls in my WINDOWS folder.
> jeff
> Harold Jhon Jairo Velásquez Vanegas wrote:
> > Hi all,
> > I'm try to install MapServer 4.4 in a windows XP machine with IIS. I
> > follow the instructions of the REAME file and execute mapserv -v whitout
> > errors. My problem is when I try to test mapserv.exe in my browser
> > appear this message:
> > CGI Error
> > The specified CGI application misbehaved by not returning a complete set
> > of HTTP headers. The headers it did return are:
> > Could anyone help me with this??
> > Thanks
> > *Harold Jhon Jairo Velásquez Vanegas*
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041221/1e95399a/attachment.html
