Click -> map coords
Aaron Craig mercutio at POBOX.COM
Wed Dec 22 03:57:31 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
That's what I figured.  My question now is this:  is there a
"standard" way of going from map extent to an 'optimum' SIZE setting
in the mapfile?
Eric Bridger wrote:
| On Tue, 2004-12-21 at 05:25, Aaron Craig wrote:
| The above function will only work when your map's SIZE matches your
|  map's EXTENTS. That is the aspect ratio's must match. E.g. w/h =
| maxx - minx / maxy - miny or width/height  =  max longitude - min
| longitude/ max latitude - min latitude. (I think I have this right)
| The easiest thing to do is just adjust your map SIZE. Should get
| rid of your white areas as well.
Aaron Craig
mercutio at pobox.com
Get Firefox!
http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
Falstaff sweats to death and lards the lean earth as he walks along.
- --I Henry IV, II:2
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.3-nr1 (Windows 2000)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFByTb7oyEQRcU83p4RAuXYAJ4yICOEJQXf29yS69koAga6FsXDfACcClB/
q4rz9FITSaN9Q94J9f9ObDE=
=S9/8
-----END PGP SIGNATURE-----
