wfs GetFeature request
Bart van den Eijnden
bartvde at XS4ALL.NL
Sun Dec 26 07:50:37 EST 2004
Within is a spatial filter to get data within a certain box, it cannot be
used to filter the properties you want to get returned from Mapserver WFS.
Best regards,
Bart
On Wed, 22 Dec 2004 09:10:30 -0600, N Zhou <zhou_naijun at HOTMAIL.COM> wrote:
> Hi Bart,
> Thank you very much for your comment. Instead of using propertyname
> outside
> Filter, I tried to get a property in Filter, but I still got the whole
> set
> of properties.
> http://myhost/cgi-bin/mapserv?map=/mymap.map&Service=WFS&version=1.0.0&Request=GetFeature&Typename=water&FILTER=<Filter><Within><PropertyName>water/PID</PropertyName><gml:Box><gml:coordinates>minx,miny
> maxx,maxy</gml:coordinates></gml:Box></Within></Filter>
> Is this a correct URL request to get a property of PID?
> Thanks.
> Naijun
>> From: "Bart van den Eijnden" <bartvde at xs4all.nl>
>> To: "N Zhou" <zhou_naijun at hotmail.com>, MAPSERVER-USERS at lists.umn.edu
>> Subject: Re: [UMN_MAPSERVER-USERS] wfs GetFeature request
>> Date: Tue, 21 Dec 2004 20:43:30 +0100
>> Hi,
>> AFAIK this is not implemented, see also:
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=675
>> Although this specific bug is about a HTTP POST request, it references
>> the
>> same feature which is missing (filtering fields/properties).
>> Best regards,
>> Bart
>> On Tue, 21 Dec 2004 13:41:11 -0600, N Zhou <zhou_naijun at HOTMAIL.COM>
>> wrote:
>>> Hi,
>>> I try to query and retrieve specific properties of a feature. My URL
>>> request
>>> is:
>>> http://myhost/cgi-bin/mapserv?map=/mymap.map&Service=WFS&version=1.0.0&Request=GetFeature&PROPERTYNAME=water/PID&Typename=water
>>> But I got the full set of properties instead of PID, like the requrest
>>> without PROPERTYNAME. Could any one tell me what is wrong with the
>>> request,
>>> or the .map file?
>>> Thank you very much!
>>> N. Zhou
>>> PS: the DescribeFeatureType returned:
>>> <?xml version="1.0" encoding="ISO-8859-1" ?>
>>> <schema targetNamespace="http://www.ttt.org/myns"
>>> xmlns:myns="http://www.ttt.org/myns"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>> xmlns="http://www.w3.org/2001/XMLSchema"
>>> xmlns:gml="http://www.opengis.net/gml" elementFormDefault="qualified"
>>> version="0.1">
>>> <import namespace="http://www.opengis.net/gml"
>>> schemaLocation="http://www.opengis.net/gml/2.1/feature.xsd" />
>>> <element name="water" type="myns:water_Type"
>>> substitutionGroup="gml:_Feature" />
>>> <complexType name="water_Type">
>>> <complexContent>
>>> <extension base="gml:AbstractFeatureType">
>>> <sequence>
>>> <element name="MS_GEOMETRY"
>>> type="gml:PointPropertyType"
>>> nillable="false" />
>>> <element name="PID" type="string" />
>>> </sequence>
>>> </extension>
>>> </complexContent>
>>> </complexType>
>>> </schema>
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
