PHPMapscript using dynamic data
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Dec 27 02:53:40 EST 2004
why not use the Virtual Spatial Data option of OGR instead?
See:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
Best regards,
Bart
> Hi!
> I am creating a map with data like roads, cities, counties from already
> created shape files. Now i want to display some locations on the map based
> on their latitude and longitude. I've these stored in MySql db, i would
> want to fetch it dynamically from the db each time the map is requested
> and
> generated the points on the map. I tried to use a template and had 3
> fields
> viz. id, latitude, longitude in it. Then fetched the data from the db and
> used processTemplate function and passed the above three values in an
> array
> in a while loop into the processTemplate functions as it's signature
> suggests. But it doesn't seems to be working, with MS_TRUE specified as
> the
> last parameter it seems to hang and with the other option it doesn't show
> anything.
> I'm not sure if i'm using the right method.
> Can anyone advice as to what method to resort to achieve the my objective
> as described above, a small example in this regard would be of great help.
> I searched the net for some example with the advanced php mapscript
> functions but without any luck, there doesn't seem to be any good
> documentation with example available on the net on this topic.
> Any help in this regard would be very much appreciable.
> Thanks
