Timeout with REQUIRES
Abe Gillespie agillesp at VT.EDU
Tue Dec 28 17:06:07 EST 2004
A couple of other tests that also didn't fix anything.
Where REQUIRES "[Flood Zone]" works for the "Flood Elevation" layer it
won't work for the "Buildings 0" layer.  I.e.:
LAYER
  NAME "Buildings 0"
  STATUS ON
  DATA "bldg0"
  TYPE polygon
  MAXSCALE 15000
  UNITS FEET
  CLASS
   COLOR 168 168 168
   OUTLINECOLOR 97 97 97
  END
END
Renaming "Buildings" to "Foo" and then using REQUIRES "[Foo]" was
fruitless.  These two tests seem to isolate the dependent layer as
being the problem as opposed to the independent layer.
-Abe
On Dec 28, 2004, at 4:54 PM, Abe Gillespie wrote:
> Comments are inline.
> -Abe
> On Dec 27, 2004, at 7:45 PM, Steve Lime wrote:
>> Abe's right the single quote isn't a problem. The requires directive
>> was
>> mostly broken in 4.2 and probably 4.0. There were changes made in
>> portions of the code that made requires basically useless. The problem
>> was only found and fixed right before 4.4 was released.
>> I don't see anything obvious but let's try a couple of things and see
>> if
>> they help.
>> 1) You don't need ()'s nor equality tests. So
>> REQUIRES "([Buildings] = 1)" should be REQUIRES "[Buildings]" and
> Didn't change anything - still timing out.
>> REQUIRES "([Flood Zone] = 1)" should be REQUIRES "[Flood Zone]"
> Didn't change anything - continued to work w/o problems.
>> 2) Try renaming "Buildings 0" to "Buildings_0". I'm thinking there may
>> be an issue with some string comparisons someplace.
>> Please try these one at a time and let me know how it goes.
>> Steve
>>>>> Abe Gillespie <agillesp at VT.EDU> 12/27/04 4:41 PM >>>
>> Uh, no, that shouldn't be a problem.  If it was, the whole map file
>> wouldn't parse correctly.  That single quote just adds a "feet"
>> designation to the elevation measurement.  In fact, if I remove the
>> "Buildings 0" layer completely, everything runs fine.
>> -Abe
>> On Dec 27, 2004, at 5:05 PM, Ethan Alpert wrote:
>>> Look at the TEXT label for the Flood Elevation layer.
>>> TEXT ([ELEVATION]')
>>> You're missing a '
>>> I've had all kinds of problems before when I miss a " or '
>>> -e
>>> -----Original Message-----
>>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>>> On
>>> Behalf Of Abe Gillespie
>>> Sent: Monday, December 27, 2004 3:22 PM
>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>> Subject: [UMN_MAPSERVER-USERS] Timeout with REQUIRES
>>> I have two layers that look like this:
>>>   LAYER
>>>    NAME "Flood Zone"
>>>    STATUS ON
>>>    DATA "flood_zo"
>>>    TYPE polygon
>>>    MAXSCALE 300000
>>>    UNITS FEET
>>>    CLASS
>>>     COLOR 68 126 171
>>>     OUTLINECOLOR 11 57 92
>>>    END
>>>    GROUP "Layers"
>>>   END
>>>   LAYER
>>>    NAME "Flood Elevation"
>>>    STATUS ON
>>>    DATA "flood_el"
>>>    TYPE line
>>>    UNITS FEET
>>>    MAXSCALE 20000
>>>    CLASS
>>>     COLOR 68 155 255
>>>     TEXT ([ELEVATION]')
>>>     LABEL
>>>      TYPE TRUETYPE
>>>      FONT arial
>>>      SIZE 8
>>>      POSITION cc
>>>      COLOR 0 0 0
>>>      ANGLE auto
>>>      MINFEATURESIZE 1
>>>     END
>>>    END
>>>   END
>>> Notice the "REQUIRES" tag.  These two layers cause no problems.
>>> However,
>>> I also have these two layers further in the map file:
>>>   LAYER
>>>    NAME "Buildings"
>>>    STATUS ON
>>>    DATA "bldg1"
>>>    TYPE polygon
>>>    MAXSCALE 15000
>>>    UNITS FEET
>>>    LABELITEM "ADDRESS"
>>>    LABELCACHE on
>>>    LABELMAXSCALE 6000
>>>    CLASS
>>>     COLOR 220 149 146
>>>     OUTLINECOLOR 190 95 96
>>>     LABEL
>>>      MINFEATURESIZE 12
>>>      TYPE truetype
>>>      FONT arial
>>>      ANTIALIAS true
>>>      ANGLE auto
>>>      POSITION cc
>>>      COLOR 0 0 0
>>>         OUTLINECOLOR 255 255 255
>>>      BUFFER 3
>>>      SIZE 8
>>>     END
>>>    END
>>>    TOLERANCE 3
>>>    TEMPLATE "x"
>>>    METADATA
>>>     search_field "FULLADDR"
>>>     search_fields "FULLADDR"
>>>     search_aliases "Address"
>>>    END
>>>    GROUP "Layers"
>>>   END
>>>   LAYER
>>>    NAME "Buildings 0"
>>>    STATUS ON
>>>    DATA "bldg0"
>>>    TYPE polygon
>>>    MAXSCALE 15000
>>>    UNITS FEET
>>>    CLASS
>>>     COLOR 168 168 168
>>>    END
>>>   END
>>> With the "Buildings 0" layer, if I include the "REQUIRES" tag
>> MapServer
>>> will timeout.  If I remove the "REQUIRES" tag everything runs
>> smoothly.
>>>   I'm using PHP Mapscript 4.4.1.  Before I upgraded (I think it was
>>> Mapscript 4.0) this worked fine.  So something has changed between
>> then
>>> and now with the "REQUIRES" algorithm.
>>> Any ideas?
>>> Thanks.
>>> -Abe
