image swapping and extent calculation
Arnold, Micheal B. Micheal.Arnold at NSCORP.COM
Thu Dec 30 09:32:02 EST 2004
All,
When using image swapping in my map, I am having some trouble calculating
the extents of the new image that was created.  I know that I must keep
track of it on the client side since I am not refreshing the whole page, but
I can't get it to work.  I have tried using the below formula based on what
I saw in both the mapserver source code and mapserv.js:
function AdjustExtent(extent, width, height)
  var cellsize = Math.max((extent[2] - extent[0])/width, (extent[3] -
extent[1])/height);
  if(cellsize > 0) {
    var ox = Math.max((width - (extent[2] - extent[0])/cellsize)/2,0);
    var oy = Math.max((height - (extent[3] - extent[1])/cellsize)/2,0);
    extent[0] = extent[0] - ox*cellsize;
    extent[1] = extent[1] - oy*cellsize;
    extent[2] = extent[2] + ox*cellsize;
    extent[3] = extent[3] + oy*cellsize;
  return(cellsize);
Here is the projection of my map file:
PROJECTION
  "proj=longlat"
  "ellps=WGS84"
END
After the above function, I am converting to decimal degrees using these
functions:
function DetX(x)
  var mapwidth = omaxx - ominx;
  var mappixel = mapwidth / 600;
  GIS_X =  ominx + (x * mappixel);
  return GIS_X;
function DetY(y)
  var mapheight = omaxy-ominy;
  var mappixel = mapheight / 500;
  GIS_Y = omaxy - (y * mappixel);
  return GIS_Y;
This does not seem to be working for me.  Is there any call that I can make
to the mapserver CGI to get the extents of the map?
Thanks for your help.
Mike Arnold
micheal.arnold at nscorp.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041230/34de7324/attachment.html
