Make problem mapserver 4.2.5
Wim Blanken w.blanken at GEON.NL
Thu Dec 30 10:48:56 EST 2004
Hello Frank,
Thanx for your clear answer. This list is really one the strengths of
mapserver!!
I will ask my provider to install g++.
Do you think that my problem will be solved if g++ is installed?
Regards,
Wim
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, December 30, 2004 4:35 PM
Subject: Re: [UMN_MAPSERVER-USERS] Make problem mapserver 4.2.5
> On Thu, 30 Dec 2004 16:30:13 +0100, Wim Blanken <w.blanken at geon.nl> wrote:
>> Hello List,
>> Maybe a stupid question but do i really need g++ to compile mapserver?
>> If not how can i fix the following make error on a system with only the
>> gcc
>> compiler installed
>> I used no options during ./configure.
> Wim,
> The mapogr.cpp module really is C++ and requires a c++
> compiler.  However, you can invoke gcc on it, and if it is
> C++ enabled it will compile the module properly.  The problem
> may arise later at link time.  Linking using gcc instead of g++
> (or c++ as it is sometimes available) will result in the executable
> not linking in C++ support libraries that are likely required by
> mapogr.cpp.  To make this work you may need to find the name
> of the C++ support libraries and explicitly include them in the link.
> They are usually something like libstdc++.so so having -lstdc++ in
> the link line may be sufficient.
> To later these settings just edit the Makefile and alter all
> occurances of g++ to gcc and add -lstdc++ in the EXE_LDFLAGS
> variable.
> Note that it is rather unusual in my experience to have gcc
> installed without g++.  This may indicate that your GCC was
> built without C++ support in which case you will not be able to
> include the OGR support in MapServer.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
