compiling with fastcgi enabled on Windows
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Dec 31 07:40:48 EST 2004
Okay, found out this is caused by some old fprintf calls in mapwms.c.
Replacing them with msIO_fprintf solves my WMS Capabilities problem.
This is also still a problem in the current CVS release (I checked the
nightly just now).
Best regards,
Bart
On Fri, 31 Dec 2004 13:06:02 +0100, Bart van den Eijnden
<bartvde at xs4all.nl> wrote:
> Hi Frank,
> thanks. I have run into a problem runtime (in normal cgi mode, not
> fastcgi mode yet) not compile time.
> What I did was:
> -download fcgi-2.4.0
> -nmake /f makefile.nt CFG=Debug
> -put your settings into the nmake.opt file
> Everything compiles perfectly, for running mapserv.exe I now needed two
> MSVC dll's: MSVCP60D.DLL and MSVCRTD.DLL (probably because of the debug
> mode of fcgi).
> When I try to run a WMS GetCapabilities, my capabilities are mucked up.
> If I comment the FASTCGI support in the makefile, and recompile, the WMS
> GetCapabilities work as expected.
> This is the mucked up part (the last line should be where UserLayer=
> ends):
> <UserDefinedSymbolization SupportSLD="1" UserLayer= <Style>
> <Name>default</Name>
> <Title>default</Title>
> </Style>
> "0" UserStyle="1" RemoteWFS="0"/>
> Do you have any idea what's going on here?
> Best regards,
> Bart
> On Thu, 30 Dec 2004 20:53:19 -0500, Frank Warmerdam
> <fwarmerdam at GMAIL.COM> wrote:
>> On Tue, 28 Dec 2004 17:16:27 +0100, Bart van den Eijnden
>>> Hi list,
>>> has anybody compiled Mapserver in fastcgi mode on Windows?
>>> The current makefiles don't have options for enabling FASTCGI (the
>>> configure file has though for Unix/Linux), so I am looking for what to
>>> add
>>> to the makefile.vc or nmake.opt in order to get a Mapserver FastCGI.
>> Bart,
>> Sorry about that. I neglected to get the FastCGI stuff into
>> 4.4 in time. You might want to just use MapServer 4.5 (aka dev)
>> which does have stubs in the nmake.opt for FastCGI support.
>> It looks something like:
>> # FastCGI Support
>> # Uncomment, and update accordingly.
>> #FCGIDIR=C:\projects\fcgi-2.4.0
>> #FCGILIB=$(FCGIDIR)\libfcgi\Debug\libfcgi.lib
>> #FCGIINC=-I$(FCGIDIR)\include
>> #FCGIDEF=-DUSE_FASTCGI
>> EXTERNAL_LIBS=$(GD_LIBS) $(TIFF_LIB) $(JPEG_LIB) \
>> $(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
>> $(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
>> $(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
>> $(ORACLE_LIB) $(SDE_LIB) $(ICONV_LIB) $(FCGILIB)
>> NCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
>> $(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
>> $(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
>> $(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(SDE_INC)\
>> $(ICONV_INC) $(FCGIINC)
>> MS_DEFS = $(REGEX_OPT) $(STRINGS) $(POSTGIS) -DWIN32 -D_WIN32 \
>> $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
>> $(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA)
>> $(NEED_NONBLOCKING_STDERR) $(ENABLE_STDERR_DEBUG) \
>> $(GDAL) $(FCGIDEF) \
>> $(WFS) $(WFSCLIENT) $(WCS) $(PDF) $(EGIS) \
>> $(USE_GD_ANTIALIAS) $(ORACLE) $(MING_VERSION) $(SDE_OPT)
>> $(ICONV)
>> Let me know if you run into specific problems. My next FWTools
>> build of MapServer for win32 will come shipped with FastCGI
>> enabled.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for Rent
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
