GeoTIFF display problem {Scanned}
R. Paul Warriner paul at WARRINER.US
Fri Dec 31 10:43:05 EST 2004
Hello,
I rebuilt the shape index in the
directory above the GeoTIFF files:
shapes/*.shp
shapes/geotiff/*.tif
The [location] went:
from       ./*.tif
to   geotiff/*.tif
and it works.
Sorry to say, I can't tell if it was
my shape file rebuild or the
elimination of ./ in the path that
fixed this, but I do know that the
before and after shape file sizes were
identical.
Thanks for the help Siki.
Regards,
Paul
---- Original message ----
>Date: Fri, 31 Dec 2004 12:53:59 -0100
>From: Siki Zoltan <siki at AGT.BME.HU>
>Subject: Re: [UMN_MAPSERVER-USERS]
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Hi,
>Check the path in your tileindex
table (location column).
>There were some issues about relative
pathes.
>I use relative path to the map file.
>Bye
>Zoltan
>On Thu, 30 Dec 2004, R. Paul Warriner
wrote:
>> Thank you David and Siki for the
replies.
>> I did as suggested, and I can get my
>> index and image if defined
individually,
>> but when tying to access with
>> TILEINDEX/TILEITEM it fails.!?
>> (I am working with mapserver 4.4.0
and
>> gdal 1.2.3)
>> #works
>> LAYER
>>        NAME "geoindex"
>>        DATA
>> "mapsurfer/shapes/geotiff/geoindex.s
hp"
>>        STATUS ON
>>        TYPE POLYGON
>>        CLASS
>>         STYLE
>>           OUTLINECOLOR 0 0 0
>>           COLOR -1 -1 -1
>>         END
>>        END
>> END
>> #works
>> LAYER
NAME "w_10950988_12_07200_col_2002"
>>        DATA
>> "mapsurfer/shapes/geotiff/w_10950988
_12_07200_col_2002.tif"
>>        TYPE RASTER
>> #       MINSCALE 700
>> #       MAXSCALE 3000
>>        STATUS ON
>> END
>> #seg fault #11
>> LAYER
>>        TILEINDEX
>> "mapsurfer/shapes/geotiff/geoindex"
>>        TILEITEM "Location"
>>        STATUS ON
>>        TYPE RASTER
>>        MINSCALE 700
>>        MAXSCALE 3000
>> END
