[Mapserver-users] area Calculation in polygon-shapes
Jan Hartmann
jhart at frw.uva.nl
Mon Feb 2 09:43:03 EST 2004
Margaritha Vogt wrote:
> Hello,
> is there an existing function in PHP-MapScript to calculate areas from a
> polygon-shape
> (like "shape.return area" in ArcView).
> Or any other possibility to get area and perimeters from shapes?
> Thanks for answering
> Maggy
I don't think there is such a function in PHP-MapScript (there is one in
PostGIS). It is quite easy to write one however. To get the area, just
iterate through the points of the ShapeObj and apply the formula below.
Perimeter is even simpler: get the length of each line segment
(Pythagoras) and sum those.
quoted from:
http://www.faqs.org/faqs/graphics/algorithms-faq/ , section 2.01:
The signed area can be computed in linear time by a simple sum.
The key formula is this:
If the coordinates of vertex v_i are x_i and y_i,
twice the signed area of a polygon is given by
2 A( P ) = sum_{i=0}^{n-1} (x_i y_{i+1} - y_i x_{i+1}).
Here n is the number of vertices of the polygon, and index
arithmetic is mod n, so that x_n = x_0, etc. A rearrangement
of terms in this equation can save multiplications and operate on
coordinate differences, and so may be both faster and more
accurate:
2 A(P) = sum_{i=0}^{n-1} ( x_i (y_{i+1} - y_{i-1}) )
Here again modular index arithmetic is implied, with n=0 and -1=n-1.
This can be avoided by extending the x[] and y[] arrays up to [n+1]
with x[n]=x[0], y[n]=y[0] and y[n+1]=y[1], and using instead
2 A(P) = sum_{i=1}^{n} ( x_i (y_{i+1} - y_{i-1}) )
HTH,
Jan
