[Mapserver-users] msOracleSpatialLayerGetShape()
Wim Blanken PI
wim.blanken at planet.nl
Mon Feb 2 09:49:22 EST 2004
Hello Merlijn,
I had a simular problem a few months ago.
There is another possibility to use Oracle Spatial with Mapserver but you
have
to use OGR with the Oracle Spatial option compiled into it. Then you have
the
full access to query etc.
If you work on Linux this is possible (if you install the oracle client on
the linux box and compile ogr with
the oracle option and then compile mapserver with ogr).
If you work on Windows this is harder as you have to compile OGR on this
platform.
I had no access to a Windows C++ compiler so I switched to Linux.
The OGR option may be a bit slower as OGR stands between Mapserver and
Oracle.
Regards,
Wim Blanken
The Netherlands
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 02, 2004 3:26 PM
Subject: [Mapserver-users] msOracleSpatialLayerGetShape()
> Hello,
> I have made a JavaScript based mapviewer. I make a selection using the
input
> 'imgbox'. On a shapefile the selection works just fine, but when I try it
on
> a layer from Oracle 9, I get the error "msOracleSpatialLayerGetShape():
> OracleSpatial error. Function not implemented yet". I read in a mailing
list
> archive in a message form 11th January 2002 saying that this method will
be
> implemented soon. Does anybody know if this function is implemented yet,
but
> has to be called differently or does anybody know a workaround without
using
> php.
> Thanks for any help.
> Cheers,
> Merlijn
> _______________________________________________________________
> Vicrea Solutions B.V.
> Vanadiumweg 11k 3812 PX Amersfoort
> Postbus 1489 3800 BL Amersfoort
> Email: m.simonse at vicrea.nl
> Tel: +31 33 4604080
> Fax: +31 33 4604088
> Internet: www.vicrea.nl
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
