[Mapserver-users] Outlinecolor of a MS_LAYER_LINE Type
Nicol Hermann
mapserver at geochem.de
Mon Feb 2 12:08:55 EST 2004
Hi Daniel, hi Steve,
thank you for your assistance. Now it works.
Thanks again
Nicol
Am Mon, 2004-02-02 um 15.19 schrieb Daniel Morissette:
> woodbri at swoodbridge.com wrote:
> > Daniel,
> > Does not look like any of the OVERLAY* attributes of the CLASS object
> > are documented in the PHP/Mapscript. Can you tell Nicol if they are
> > supported in the code?
> > Nicol,
> > You might try to just set them in mapscript like any other object
> > attribute:
> > $classObj->set("OVERLAYCOLOR", $colorObj);
> > $classObj->set("OVERLAYSIZE", 3);
> > It may just work and not be documented.
> In V4.0, OVERLAYCOLOR and all OVERLAY* parameters are supported only for
> backwards compatibility in the mapfiles. Instead of using OVERLAY*, you
> would create a second style in your class for the overlay part and use
> the color and size parameters of the second style to set what used to be
> the OVERLAYCOLOR and OVERLAYSIZE. The methods to create styles and set
> their parameters are in the 4.0 docs.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
