[Mapserver-users] MapServer 4.0 Tutorial problems
Pericles Nacionales
nacional at cbs.umn.edu
Mon Feb 2 14:29:25 EST 2004
Hi there! Can you have a look at your web server's error log and see if
there's anything pertinent to the TrueType error you're getting? You
might also want to check the permissions on your fonts and fonts
directory--make sure the web server account have access to the
directory/read access to files.
Cheers!
-Perry N.
On Mon, 2 Feb 2004 mapserver at digger.net wrote:
> I've been going through the tutorial, and have run into some problems with it.
> The first one is in exercise 1-4, where labeling is introduced. These lines:
> TYPE TRUETYPE
> FONT arial-bold
> cause an "Internal Server Error" from Apache. The TYPE line by itself just
> produces this (as expected):
> msGetLabelSize(): TrueType Font error. Requested font (NULL) not found.
> But when both are present, MapServer fails. Where might I look for a solution
> to this? "mapserv -v" reports:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Thanks,
> Dave
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
