[Mapserver-users] I have some landsat 7 data that I want to tile : overlap + transparency
Stephen Clark
stephen.clark at focus.ca
Mon Feb 2 17:33:57 EST 2004
Frank,
Point taken about the return receipt requested set on. Will turn it off.
I am not sure what the problem is with these ECW files. I think that it is
the TRANSPARENCY but am not sure.
I downloaded the TIFF files and then compresed them to ECW then used
gdaltindex on them to create a tile.
Files:
My landsat data is from the Geogratis web site :
http://geogratis.cgdi.gc.ca/download/landsat_7/ortho/geotiff/utm/
Specifically these three scenes as example:
http://geogratis.cgdi.gc.ca/download/landsat_7/ortho/geotiff/utm/047021/
http://geogratis.cgdi.gc.ca/download/landsat_7/ortho/geotiff/utm/048021/
http://geogratis.cgdi.gc.ca/download/landsat_7/ortho/geotiff/utm/049021/
Note: Creating a tile using the raw TIFF files produces no "Black Fuzziness
around the scenes "
Stephen Clark wrote:
> There is a residual amount of black fuzziness around the scenes after
using
> the above OFFSITE command.
That is pretty much inevitable if you use ECW. Lossy compression formats
will not maintain nodata areas cleanly.
Q1: Is there a way of specifying a range of values for the OFFSITE command
to handle the lossy compression fuzziness?
Q2: The transparency values do not work for a tiled raster file (TIFF and
ECW) using the links posted above. It believe it to be an error.
> I am not eager to allow different offsite values for each file selected
from
> the tileindex. However, if there is one offsite value in your layer
definition
> it should be used for all the tiles in the layer. Is this not happening?
Or
> was it layer transparency (ala TRANSPARENCY keyword) that was not working?
I
> think I asked this before and then lost your answer in the flood of
> correspondence on the issue.
Q3: I would like the ability to specify an individual TRANSPARENCY and
OFFSITE value for each raster file before creating a tile. That way I could
create a mosaic from many raster files and have the best part of each image
viewable. Would this be a tremendous amount of work?
Thanks
Stephen
----- Original Message -----
To: "Stephen Clark" <stephen.clark at focus.ca>
Sent: Monday, February 02, 2004 12:40 PM
Subject: Re: [Mapserver-users] I have some landsat 7 data that I want to
> > Frank,
> > Did you get the attached images I sent regarding this issue? The issue
> > relates to me wanting to produce 300 DPI images in a PDF using the
Landsat 7
> > data.
> Stephen,
> I did get a pointer to where to download them from, but I didn't do that.
> I have no opinion on all the scale related issues.
> >>My use of Landsat 7 Imagery is for a backdrop in my PDF files. But I
> >>cannot get the WMS server to produce a 300 dpi image so I need to copy
> >>them locally to produce the 300 dpi PDF files.
> > I am working on using the BBOX, Width and Height parameters instead but
I
> > have had no luck.
> > The original problem I posed to you was why I could not place
transparency
> > in each Landsat scene as I created the Tiled index using GdalTindex. So
> > what do you think on the this issue?
from
definition
Or
I
> PS. it's a bit annoying to have return receipt requested set on. The only
> time I do this is with the property manager at our condo because she is so
> slack about replying. It kinds of makes me feel like a kid being checked
up
> on!
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
