[Mapserver-users] Configure - help
Keith Campbell
scoota at supanet.com
Mon Feb 2 16:40:45 EST 2004
Thank you Frank,
Your advise has solved the problem.
Keith
Frank Koormann wrote:
>Keith,
>* Keith Campbell <scoota at supanet.com> [040202 00:48]:
>>Hi All,
>>Can anybody help with this?
>>Running configure (on a Solaris) produces the following messages:-
>>checking if GDAL support requested... yes, user supplied gdal-config
>>(/export/home/local/util/gdal/configure)
>you mustn't specify the path to the configure script of the gdal source
>package but the path to the program called 'gdal-config' which should
>be build and installed with gdal.
>Regrads,
> Frank
