[Mapserver-users] I have some landsat 7 data that I want to tile : overlap + transparency
Mon Feb 2 17:20:57 EST 2004
Stephen Clark wrote:
> Frank,
>>If you are wanting to use transparency as a mechanism to blend overlapping
>>tiles you are out of luck I am afraid.
> Essentially this is what I want to do.
> I will have to create a mosaic to produce the imagery results I want for
> now.
> Could some basic mosaicing functions be added to gdal in the future?
Stephen,
GDAL has some basic mosaicing functions now.  In the sense that gdalwarp can
be used to successivly overlay component images into a mosaic.  This includes
control of "nodata" values for each pass.  However, it doesn't include
cutline support or feathering across cutlines which would be quite desirable.
This is definately a direction I would like to go with GDAL.
Best regards,
