[Mapserver-users] Mapserver WFS performance
Yewondwossen Assefa assefa at dmsolutions.ca
Mon Feb 2 17:34:32 EST 2004
I have added 2 enhencements bugs (552 and 553) to keep track of these
discussions.
Later,
Frank Warmerdam wrote:
> Yewondwossen Assefa wrote:
>> Here is how things work :
>>   - the user does a wfs request
>>   - in is translated in mapserver query : the query does not take into
>> account the maxfeatures.
>>    - The MAXFEATURES is taken into account when generating the
>> resulting   gml file
>>   So yes, It ends up doing the query on all the shapes in your case.
>>  I think we should modify mapserver low level query functions to be
>> able to pass a maxfeature parameter. Some of the query functions have
>> a mode (single or mulitple), and this notion should be extended to
>> support a maxfeature. Once this is done the wfs interface can take
>> advantage of it.
> Assefa, and others,
> On a vaguely related note, the current query interface seems to make a
> pass generating the 'item ids' for all the features which match the
> query.  Then when the query is returned another pass is made fetching the
> shapes by id.  With shapefiles this isn't particularly expensive, though it
> does presumably result in the features being parsed from the binary twice.
> But for some OGR supported formats fetching "by id" can be very expensive.
> If we are restructuring the query mechanism what are the chances of
> reviewing
> this whole two pass approach?  Since WFS is basically always using the
> query mechanism it seems this is a significant performance issue for some
> WFS setups.  Even for "good formats" there is a bunch of overhead.
> Of course, I may be mis-understanding how things are working ... I've only
> glanced at it.
> Best regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
