[Mapserver-users] Too hard, too easy or too boring?
Paul Ramsey
pramsey at refractions.net
Tue Feb 3 20:12:17 EST 2004
More likely there really is an alignment error in the mapserver code.
It is moderately easy to get them if you are not used to writing
portable code and are only testing on Linux/x86. As we have found,
since everyone except Dave has added one to PostGIS at one point or
another (and Dave is only good because he did all the initial
development on Solaris).
If Steve or the folks from DM would like access to a Solaris box for
testing, I can arrange one.
Paul
On Tuesday, February 3, 2004, at 04:07 PM, Pericles Nacionales wrote:
> I'm not a Solaris user but you might need additional FLAGS/LIBS to get
> MapServer to work on that platform. Look at XTRALIBS in your Makefile
> and
> make sure "-lm -lstdc++" are there. Perhaps it will work with other,
> comparable libs.
> Just guessing.
> -Perry
> On Tue, 3 Feb 2004, Keith Campbell wrote:
>> OK, just trying to get your attention. I posted this yesterday under a
>> different title and got no responses.
>> Here's the problem. I'm trying to compila an install a WFS Server
>> enabled Mapserver on a Solaris (this is proving to be a very
>> frustrating
>> experience, no doubt partly due to my lack of knowledge of UNIX). I
>> think I've got all the libraries installed that I need, even though
>> they
>> are in non-standard locations (it's not my server). The configure
>> script
>> runs to completion and only seems to complain once:-
>> checking for httpd... /export/home/local/apache2/bin/httpd
>> awk: syntax error near line 1
>> awk: bailing out near line 1
>> /export/home/local/apache2/bin/httpd version is Apache/2.0.45
>> Not sure what this means or what the implications are.
>> Anyway, this is what I fed into the configure:-
>> bash$ ./configure --with-jpeg=/export/home/local/util/jpeg
>> --with-freetype=/exp
>> ort/home/local/util/freetype --with-zlib=/export/home/local/util/zlib
>> --with-pn
>> g=/export/home/local/util/libpng
>> --with-libiconv=/export/home/local/util/libico
>> nv --with-gd=/export/home/local/util/gd-2.0.15
>> --with-proj=/export/home/local/u
>> til/proj --with-ogr=/export/home/local/util/gdal/apps/gdal-config
>> --with-gdal=
>> /export/home/local/util/gdal/apps/gdal-config --with-wfs
>> --with-postgis
>> The make process ran for some time before spitting this out:-
>> ld: fatal: relocation error: R_SPARC_32: file ./libmap.a(mapogr.o):
>> symbol <unkn
>> own>: offset 0xfd6609c9 is non-aligned
>> symbol <unkn
>> own>: offset 0xfd660a09 is non-aligned
>> symbol <unkn
>> own>: offset 0xfd660a69 is non-aligned
>> symbol <unkn
>> own>: offset 0xfd660c29 is non-aligned
>> collect2: ld returned 1 exit status
>> make: *** [shp2img] Error 1
>> I can't find anything in the archives that points to the cause of
>> this.
>> Can anybody help?
>> Thanks,
>> Keith
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
