[Mapserver-users] Querying on multiple fields
Roger Boily
boily at bsw.org
Wed Feb 4 02:58:54 EST 2004
This is a multi-part message in MIME format.
--------------090503090003060205050000
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Hi Stephen,
Thanks for answering. Yes, I've escaped the spaces with %20 and tried to
escape ' with %27 too.
No way to make it run. I had it working for one year with MapServer 3.6
(both Linux and Win) and it works
fine also with the qstring modifications on MapServer 4.0 for Windows,
but I can't figure out where is
the problem with Linux (tested on two servers). Even the simple
&qstring=('[PART_N]' IN '556') does not
work. It works fine with &qitem=PART_N&qstring=556 .
To help you in helping me :-), I have made an example on my local
testing server:
The first url works properly and the second one fails.
http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qitem=FOGLIO_N&qstring=10
http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qstring=('[FOGLIO_N]'%20IN%20'10')
I attach also the map file.
I need the second one to work because I have to query two fields at once.
ex: FOGLIO_N = 10 AND PART_N = 254
Thanks in advance, Roger
MAP FILE: urbis.map
NAME urbis
STATUS ON
SIZE 650 400
EXTENT 475.66 2404.5 5974.34 6239.61
UNITS meters
SHAPEPATH "data"
IMAGETYPE PNG
IMAGECOLOR 153 153 153
TRANSPARENT ON
FONTSET "/var/www/html/sittel/procida/font/fonts.txt"
WEB
TEMPLATE header_1024.html
IMAGEPATH '/var/www/html/tmp/'
IMAGEURL '/tmp/'
MINSCALE 100
END #WEB
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0 # highlight color is yellow
END
###### LAYER C A T A S T O ###########
LAYER
NAME 'catasto'
TYPE Polygon
STATUS ON
DATA 'lotti'
# TEMPLATE index_basso.phtml
LABELITEM 'PART_N'
MAXSCALE 25000
CLASS
Name 'catasto'
LABEL
TYPE TRUETYPE
FONT time
BUFFER 3
COLOR 255 0 0
POSITION CC
SIZE 8
END
OUTLINECOLOR 100 255 000
END # CLASS
END # LAYER
###### LAYER F O G L I ########
LAYER
NAME "fogli"
TYPE Polygon
STATUS ON
DATA "fogli"
LABELITEM 'FOGLIO_N'
CLASS
Name 'foglio'
TEXT (Foglio [FOGLIO_N])
LABEL
TYPE TRUETYPE
FONT time
BUFFER 1
COLOR 0 0 0
POSITION auto
SIZE 10
END
OUTLINECOLOR 255 255 255
END # CLASS
END # LAYER fogli
END
End of map file
Steve Lime wrote:
>Are you escaping the value ('[PART_N]' IN '556,557' AND '[ID_N]' IN
>'24') properly? Spaces aren't allowed and should be replaced with either
>a + or a %20. We should still track down the source of the error though,
>error 500's are never good.
>Steve
>Stephen Lime
>Data & Applications Manager
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
>>>>Roger Boily <boily at bsw.org> 2/3/2004 6:33:11 AM >>>
>Hi,
>On a cgi url I've tried to query on multiple fields with this:
>NB: for easy reading space and " are normals but I used %20(space) and
>%27(')
>&qstring=('[PART_N]' IN '556,557' AND '[ID_N]' IN '24')
>it works perfectly on windows Mapserver 4.0.1
>But I receive error 500 from Apache on linux: (Premature end of script
>headers: mapserv)
>&qitem=PART_N&qstring=556 works fine on linux
>but I receive the same error with:
>Is there anyone who has any idea?
>Is there a way to make multiple fileds query with qitem and qstring?
>Thanks a lot
>Roger
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
<tt>Hi Stephen,<br>
to escape ' with %27 too.<br>
(both Linux and Win) and it works<br>
but I can't figure out where is<br>
the problem with Linux (tested on two servers). Even the simple </tt><tt>&qstring=('[PART_N]'
IN '556') does not<br>
work. It works fine with &qitem=PART_N&qstring=556 .<br>
testing server:<br>
The first url works properly and the second one fails.<br>
<a class="moz-txt-link-freetext" href="http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qitem=FOGLIO_N&qstring=10">http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qitem=FOGLIO_N&qstring=10</a><br>
<a class="moz-txt-link-freetext" href="http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qstring=(">http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qstring=(</a>'[FOGLIO_N]'%20IN%20'10')<br>
I attach also the map file.<br>
once.<br>
ex: FOGLIO_N = 10 AND PART_N = 254<br>
<br>
Thanks in advance, Roger<br>
<br>
----------------------------<br>
MAP FILE: urbis.map<br>
NAME urbis<br>
STATUS ON<br>
SIZE 650 400<br>
EXTENT 475.66 2404.5 5974.34 6239.61<br>
UNITS meters<br>
SHAPEPATH "data"<br>
IMAGETYPE PNG<br>
IMAGECOLOR 153 153 153<br>
TRANSPARENT ON<br>
FONTSET "/var/www/html/sittel/procida/font/fonts.txt"<br>
<br>
WEB<br>
TEMPLATE header_1024.html<br>
IMAGEPATH '/var/www/html/tmp/'<br>
IMAGEURL '/tmp/'<br>
MINSCALE 100<br>
END #WEB<br>
<br>
QUERYMAP<br>
STATUS ON<br>
STYLE HILITE<br>
COLOR 255 255 0 # highlight color is yellow<br>
END<br>
<br>
###### LAYER C A T A S T O ###########<br>
LAYER<br>
NAME 'catasto'<br>
TYPE Polygon<br>
STATUS ON<br>
DATA 'lotti'<br>
# TEMPLATE index_basso.phtml<br>
LABELITEM 'PART_N'<br>
MAXSCALE 25000<br>
CLASS<br>
Name 'catasto'<br>
LABEL<br>
TYPE TRUETYPE<br>
FONT time<br>
BUFFER 3<br>
COLOR 255 0 0<br>
POSITION CC<br>
SIZE 8<br>
END<br>
OUTLINECOLOR 100 255 000<br>
END # CLASS<br>
END # LAYER<br>
<br>
###### LAYER F O G L I ########<br>
LAYER<br>
NAME "fogli"<br>
TYPE Polygon<br>
STATUS ON<br>
DATA "fogli"<br>
LABELITEM 'FOGLIO_N'<br>
CLASS<br>
Name 'foglio'<br>
TEXT (Foglio [FOGLIO_N])<br>
LABEL<br>
TYPE TRUETYPE<br>
FONT time<br>
BUFFER 1<br>
COLOR 0 0 0<br>
POSITION auto <br>
SIZE 10<br>
END<br>
OUTLINECOLOR 255 255 255<br>
END # CLASS<br>
END # LAYER fogli<br>
<br>
END<br>
----------------------------------<br>
End of map file<br>
<br>
</tt><tt>Steve Lime wrote:</tt><br>
<blockquote type="cite" cite="mids01fcfe4.004 at co5.dnr.state.mn.us">
<pre wrap="">Are you escaping the value ('[PART_N]' IN '556,557' AND '[ID_N]' IN
Steve
Stephen Lime
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
</pre>
<blockquote type="cite">
<pre wrap="">Roger Boily <a class="moz-txt-link-rfc2396E" href="mailto:boily at bsw.org"><boily at bsw.org></a> 2/3/2004 6:33:11 AM >>>
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->Hi,
%27(')
headers: mapserv)
Thanks a lot
Roger
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
</pre>
</blockquote>
</body>
</html>
--------------090503090003060205050000--
