[Mapserver-users] Too hard, too easy or too boring?
Keith Campbell scoota at supanet.com
Wed Feb 4 15:59:37 EST 2004
Patrick,
Thanks for your reply. I've tried your suggestion first, as it seemed
the simplest. However, no happy ending as in your case, same result as
before.
Keith
Patrick J Barabe wrote:
>Keith,
>Try again with --enable-runpath in your configure options.  I had
>compile errors for weeks that never got better until I noticed the
>reference that that option in README.CONFIGURE.  First try with that
>option and all my problems evaporated.  This on Solaris 9.
>good luck,
>patrick
>On Tue, 3 Feb 2004, Keith Campbell wrote:
>>OK, just trying to get your attention. I posted this yesterday under a
>>different title and got no responses.
>>Here's the problem. I'm trying to compila an install a WFS Server
>>enabled Mapserver on a Solaris (this is proving to be a very frustrating
>>experience, no doubt partly due to my lack of knowledge of UNIX). I
>>think I've got all the libraries installed that I need, even though they
>>are in non-standard locations (it's not my server). The configure script
>>runs to completion and only seems to complain once:-
>>checking for httpd... /export/home/local/apache2/bin/httpd
>>awk: syntax error near line 1
>>awk: bailing out near line 1
>>        /export/home/local/apache2/bin/httpd version is Apache/2.0.45 ().
>>Not sure what this means or what the implications are.
>>Anyway, this is what I fed into the configure:-
>>bash$ ./configure --with-jpeg=/export/home/local/util/jpeg
>>--with-freetype=/exp
>>ort/home/local/util/freetype --with-zlib=/export/home/local/util/zlib
>>--with-pn
>>g=/export/home/local/util/libpng
>>--with-libiconv=/export/home/local/util/libico
>>nv --with-gd=/export/home/local/util/gd-2.0.15
>>--with-proj=/export/home/local/u
>>til/proj --with-ogr=/export/home/local/util/gdal/apps/gdal-config
>>--with-gdal=
>>/export/home/local/util/gdal/apps/gdal-config --with-wfs --with-postgis
>>The make process ran for some time before spitting this out:-
>>ld: fatal: relocation error: R_SPARC_32: file ./libmap.a(mapogr.o):
>>symbol <unkn
>>own>: offset 0xfd6609c9 is non-aligned
>>symbol <unkn
>>own>: offset 0xfd660a09 is non-aligned
>>symbol <unkn
>>own>: offset 0xfd660a69 is non-aligned
>>symbol <unkn
>>own>: offset 0xfd660c29 is non-aligned
>>collect2: ld returned 1 exit status
>>make: *** [shp2img] Error 1
>>I can't find anything in the archives that points to the cause of this.
>>Can anybody help?
>>Thanks,
>>Keith
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>** /          #####                        patrick barabe / *
>* /          @(0 0)@               pbarabe at u.arizona.edu / **
>*/------oOOo---[_]---oOOo--- www.u.arizona.edu/~pbarabe / ***
