[Mapserver-users] Point display question
Steve Lime
steve.lime at dnr.state.mn.us
Wed Feb 4 22:36:29 EST 2004
At the moment you can't rotate symbols. You can rotate labels though so
you could use a symbol ttf file for "symbols" and then use the
LABELANGLEITEM property to rotate things feature-by-feature. I know
folks are doing this with weather symbols like wind barbs and it works
great.
Steve
>>> Amit S BEHERE <abehere at cs.ucsd.edu> 02/04/04 7:08 PM >>>
Hi all,
I have a mapfile that shows points on a map using a symbol. The points
are
in a shapfile which among other things has a field for the rotation
angle
for the symbol (i.e the dbf database associated with the shapefile has a
column for rotation angle). Is there a way by which I could display the
symbol rotated at the angle given in the table.
Here is my layer definition:
LAYER
NAME "sewerstructures"
TITLEINDEX vernon_global_index
TITLEITEM FILES
CLASSITEM "Style"
DATA "sewerstructures"
STATUS ON
TYPE POINT
MAXSCALE 32000
MINSCALE 1
CLASS
EXPRESSION ('[STYLE]' eq 'Manhole-Vernon')
COLOR 0 0 0
OUTLINECOLOR 0 0 0
size 9
symbol 1
END
END
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just
changes
the rules"......Vishwanathan Anand
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
