[Mapserver-users] integrating HTML Legends with dbox/javascript
landview framework
Emilio Mayorga
emiliom at u.washington.edu
Thu Feb 5 03:05:50 EST 2004
Here's the URL:
http://basin.ocean.washington.edu/mapserv/mapache/eng/mnfr_ecosyst_iframetest.html
I set up this page only to test this specific functionality.
The first time you go there, you won't see the legend; it'll come up
only after you do something, like pan or zoom. There isn't much to see,
really (View Source won't show the html that's been pulled from the
iframe into the div). But if you use Mozilla, you can use the DOM
Inspector and see everything as it reacts to your actions.
The div element where I insert the legend page sucked from the iframe is
a simple element, not like your dbox object that's a div within a div.
I kind of like that simplicity, as long as I can solve the "out of sync"
bug.
BTW, I'm no DOM/DHTML/javascript guru; but I'm pretty decent at
prototyping and following my nose!
Thanks.
-Emilio
Steve Lime wrote:
> Got a place where we can see this in action?
> I'm still very interested, but I've not had time to work on the problem.
> My theoretical approach is to treat the legend just like a dbox object,
> a absolutely positioned, scrollable layer anchored to an absolutely
> positioned anchor. I've found a slick way to suck a remote page into a
> javascript string and then can use innerHTML to swap in the new page. I
> had planned to simply use mode=legend with HTML legends. I don't believe
> need code outside the legend tags to make it work.
> Sounds like you're working in the same direction. Anyway, I'd love to
> see it. That may help with ideas/fixes...
> Steve
>>>>Emilio Mayorga <emiliom at u.washington.edu> 02/04/04 10:25 PM >>>
> Hi (specially Steve Lime),
> A few weeks ago I asked about HTML legends and the DHTML/javascript
> "landview" application. The problem was this: how do you load into the
> page the result of the cgi statement that creates the HTML legend? I
> found a partial solution using an iframe, and someone else mentioned
> their own solution -- which, while it worked fine, it was implemented
> using a cross-browser DHTML/javascript library other than CBE. Steve,
> since you mentioned you were interested in this topic, I'm reporting
> some progress I made.
> A problem with using an iframe element is that the html legend becomes
> isolated from the rest of the document -- it's its own document. Also,
> the HTML Legend parser ignores all html outside the special tags in the
> legend template file. So, you can't define an external CSS file or add
> javascript code to the html legend. That's a real bummer.
> * Here's what I've done. I use an "invisible" iframe. I define the
> iframe element, give it an id attribute, and set the element visibility
> to hidden. I also define an empty div element, with an id:
> <iframe id="legendiframe" src="blank.html" style="visibility:hidden"
> width="1" height="1" scrolling="auto" frameborder="0">
> [your browser can't display frames]
> </iframe>
> <div id="legenddiv"></div>
> * In the postdraw() function, I update the legend by setting the src
> attribute of the iframe to the HTML legend cgi line. Then, I use the
> iframe's contentDocument property and innerHTML to suck in all the HTML
> & text found within the iframe body element, then stuff it on my empty
> div, again using innerHTML.
> // update the legend
> var legifrm = document.getElementById("legendiframe");
> legifrm.src = MapServer + "?map=" + mapfile + "&mode=legend&mapext=0+0+"
> + (ms.extent[2] - ms.extent[0]) + "+" + (ms.extent[3] - ms.extent[1]) +
> "&mapsize=" + ms.width + "+" + ms.height;
> // contentDocument is defined in the W3C DOM, but contentWindow is
> // the only method in the IE DOM; Mozilla 1+ (NN7+) defines both
> if (document.getElementById("legenddiv"))
> var ifrmdoc = (legifrm.contentDocument) ? legifrm.contentDocument :
> ((legifrm.contentWindow) ? legifrm.contentWindow.document : null);
> var getiframebody = ifrmdoc.getElementsByTagName("body");
> document.getElementById("legenddiv").innerHTML =
> getiframebody[0].innerHTML;
> * It works! It's very flexible because you can stuff the HTML legend
> content into any element you want, not just a div; for example, adding
> rows to a table element, or adding a complete table with rows. It's also
> very clean and simple, though using innerHTML is a little inelegant. And
> of course, now your legend html is exposed to the general context,
> external CSS, javascript, etc.
> HOWEVER, there is one bug: the resulting legend content is always one
> step behind the actual current legend. It's very noticeable if you have
> scale-specific classes and the legend flags are set to be sensitive to
> scale. I think it has to do with the div element not knowing that the
> content of the iframe has been updated, but I can't figure it out.
> Steve, any suggestions??
> -Emilio Mayorga
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
