[Mapserver-users] Mapserver 1rst install : can't display raster layer
Tony Jolibois
Tony.Jolibois at cls.fr
Thu Feb 5 04:50:42 EST 2004
--=====================_715552250==_
Content-Type: multipart/alternative;
boundary="=====================_715552280==_.ALT"
--=====================_715552280==_.ALT
Content-Type: text/plain; charset="iso-8859-1"; format=flowed
Content-Transfer-Encoding: quoted-printable
>Date: Wed, 04 Feb 2004 16:51:32 +0100
>To: mapserver-users at lists.gis.umn.edu
>From: Tony Jolibois <Tony.Jolibois at cls.fr>
>Subject: Mapserver 1rst install : can't display raster layer
> Hi all,
>I've just installed mapserver4.0 on a Linux RedHat8.0 two days ago. This=20
>is my 1rst post on this list.
>When I execute the tutorial40, the mapserver can't display the raster=20
>layer : with the tiff, the mapserver crash with a segmentation fault, with=
=20
>a png it don't display it.
>I've tried a lot of different compilation, a lot of different library,=20
>always the same thing.
>Please see my last compilation options :
>mapserver4.0 : --with-gd=3Dstatic,/usr/local --with-proj=3D/usr/local=20
>--with-gdal=3D/usr/bin/gdal-config --with-tiff=3D/usr
>gd-2.0.12 : --with-gd=3Dstatic,/usr/local --with-proj=3D/usr/local=20
>proj-4.4.7 gdal-1.1.9 : --with-libz --with-png=3Dinternal --with-gif=20
>--with-jpeg=3Dinternal --with-libtiff=3Dinternal --with-geotiff=3Dinternal=
=20
>--prefix=3D/usr
>HDF4.1r5 : --host=3Di686-unknown-linux
>The command :
>mapserv QUERY_STRING=3Dmap=3D/home/map/html/tutorial/example1-5.map\&mode=
=3Dmap
>With a browser the mapserver display the vector layer and not the raster.
>I can see the stacktrace (attached) which say that it can't read tiff=
images.
>With totalview (debug), I can see that the error come with a call of a=20
>method of the gdal library.
>If someone has an idea...
>Tony
>Tony Jolibois
>CLS, Direction Oc=E9anographie Spatiale
>Tel: (+33) (0) 561 393 797
>Internet: http://www.cls.fr
Content-Type: text/html; charset="iso-8859-1"
<html>
<br>
<blockquote type=3Dcite class=3Dcite cite>Date: Wed, 04 Feb 2004 16:51:32
+0100<br>
To: mapserver-users at lists.gis.umn.edu<br>
Subject: Mapserver 1rst install : can't display raster layer<br><br>
<x-tab> </x-tab> Hi
all,<br><br>
is my 1rst post on this list. <br>
with a png it don't display it.<br><br>
always the same thing.<br>
Please see my last compilation options :<br><br>
<font face=3D"Courier, Courier"><b>mapserver4.0</b> :
--with-gdal=3D/usr/bin/gdal-config --with-tiff=3D/usr<br><br>
<b>gd-2.0.12</b> : --with-gd=3Dstatic,/usr/local --with-proj=3D/usr/local
<b>proj-4.4.7 gdal-1.1.9</b> : --with-libz --with-png=3Dinternal --with-gif
--prefix=3D/usr<br><br>
<b>HDF4.1r5</b> : --host=3Di686-unknown-linux<br><br>
</font>The command :<br>
<font face=3D"Courier, Courier">mapserv
QUERY_STRING=3Dmap=3D/home/map/html/tutorial/example1-5.map\&mode=3Dmap<=
br><br>
</font>With a browser the mapserver display the vector layer and not the
raster.<br>
images.<br><br>
method of the gdal library.<br><br>
If someone has an idea...<br><br>
Tony<br><br>
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ <br>
Tony Jolibois<br>
CLS, Direction Oc=E9anographie Spatiale <br>
Tel: (+33) (0) 561 393 797 <br>
Internet:
<a href=3D"http://www.cls.fr/" eudora=3D"autourl"><font color=3D"#0000FF"><u=
>http://www.cls.fr</a></u></font>
<br>
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~</blockquote></html>
--=====================_715552280==_.ALT--
Content-Type: text/plain; charset="us-ascii"
Content-Disposition: attachment; filename="stacktrace.txt"
execve("./mapserv", ["./mapserv", "QUERY_STRING=map=/home/map/html/tutorial/example1-5.map&mode=map"], [/* 33 vars */]) = 0
uname({sys="Linux", node="las-dev", ...}) = 0
brk(0) = 0x80e9da0
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=27032, ...}) = 0
old_mmap(NULL, 27032, PROT_READ, MAP_PRIVATE, 3, 0) = 0x40014000
close(3) = 0
open("/usr/lib/libjpeg.so.62", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0P$\0\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=140418, ...}) = 0
old_mmap(NULL, 119916, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4001b000
mprotect(0x40038000, 1132, PROT_NONE) = 0
old_mmap(0x40038000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1d000) = 0x40038000
close(3) = 0
open("/usr/lib/libfreetype.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240g\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=295833, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40039000
old_mmap(NULL, 258016, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4003a000
mprotect(0x40076000, 12256, PROT_NONE) = 0
old_mmap(0x40076000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x3c000) = 0x40076000
close(3) = 0
open("/usr/lib/libpng.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0PU\0\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=131560, ...}) = 0
old_mmap(NULL, 134568, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40079000
mprotect(0x40099000, 3496, PROT_NONE) = 0
old_mmap(0x40099000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1f000) = 0x40099000
close(3) = 0
open("/usr/lib/libz.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\31\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=59778, ...}) = 0
old_mmap(NULL, 54984, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4009a000
mprotect(0x400a6000, 5832, PROT_NONE) = 0
old_mmap(0x400a6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xb000) = 0x400a6000
close(3) = 0
open("/usr/lib/libtiff.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000<\0\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=570032, ...}) = 0
old_mmap(NULL, 271968, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x400a8000
mprotect(0x400e9000, 5728, PROT_NONE) = 0
old_mmap(0x400e9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x41000) = 0x400e9000
close(3) = 0
open("/usr/local/lib/libproj.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20]\0\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=692910, ...}) = 0
old_mmap(NULL, 203488, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x400eb000
mprotect(0x4011b000, 6880, PROT_NONE) = 0
old_mmap(0x4011b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x30000) = 0x4011b000
close(3) = 0
open("/usr/lib/libgdal.1.1.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000\37\7"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0644, st_size=3256876, ...}) = 0
old_mmap(NULL, 2972876, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4011d000
mprotect(0x40365000, 580812, PROT_NONE) = 0
old_mmap(0x40365000, 491520, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x247000) = 0x40365000
old_mmap(0x403dd000, 89292, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x403dd000
close(3) = 0
open("/lib/i686/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`7\0\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=173359, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x403f3000
old_mmap(NULL, 138292, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x403f4000
mprotect(0x40415000, 3124, PROT_NONE) = 0
old_mmap(0x40415000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x40415000
close(3) = 0
open("/lib/i686/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0Pv\1B4\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=1402035, ...}) = 0
old_mmap(0x42000000, 1264960, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x42000000
mprotect(0x4212c000, 36160, PROT_NONE) = 0
old_mmap(0x4212c000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x12c000) = 0x4212c000
old_mmap(0x42131000, 15680, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x42131000
close(3) = 0
open("/usr/lib/libmfhdf.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200^\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=128400, ...}) = 0
old_mmap(NULL, 135592, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40416000
mprotect(0x40435000, 8616, PROT_NONE) = 0
old_mmap(0x40435000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1e000) = 0x40435000
old_mmap(0x40437000, 424, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40437000
close(3) = 0
open("/usr/lib/libdf.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\6\1"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=457008, ...}) = 0
old_mmap(NULL, 625776, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40438000
mprotect(0x404a6000, 175216, PROT_NONE) = 0
old_mmap(0x404a6000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x6d000) = 0x404a6000
old_mmap(0x404a9000, 162928, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x404a9000
close(3) = 0
open("/lib/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360\31"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=12102, ...}) = 0
old_mmap(NULL, 11640, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404d1000
mprotect(0x404d3000, 3448, PROT_NONE) = 0
old_mmap(0x404d3000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x404d3000
close(3) = 0
open("/usr/lib/libstdc++-libc6.2-2.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\205"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0555, st_size=426442, ...}) = 0
old_mmap(NULL, 273928, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404d4000
mprotect(0x4050c000, 44552, PROT_NONE) = 0
old_mmap(0x4050c000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x38000) = 0x4050c000
old_mmap(0x40515000, 7688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40515000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40517000
munmap(0x40014000, 27032) = 0
brk(0) = 0x80e9da0
brk(0x80e9dd0) = 0x80e9dd0
brk(0x80ea000) = 0x80ea000
brk(0x80eb000) = 0x80eb000
getpid() = 16746
time(NULL) = 1075901373
brk(0x80f5000) = 0x80f5000
brk(0x80ff000) = 0x80ff000
open("/home/map/html/tutorial/example1-5.map", O_RDONLY) = 3
mmap2(NULL, 172032, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40518000
brk(0x8104000) = 0x8104000
ioctl(3, SNDCTL_TMR_TIMEBASE, 0xbfffe030) = -1 ENOTTY (Inappropriate ioctl for device)
ioctl(3, SNDCTL_TMR_TIMEBASE, 0xbfffe050) = -1 ENOTTY (Inappropriate ioctl for device)
brk(0x810e000) = 0x810e000
open("/usr/local/share/proj/proj_def.dat", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=261, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40014000
read(4, "# Projection library defaults fi"..., 4096) = 261
_llseek(4, 0, [0], SEEK_SET) = 0
read(4, "", 4096) = 0
close(4) = 0
munmap(0x40014000, 4096) = 0
getcwd("/tmp/mapserver/mapserver-4.0.1", 1024) = 31
fstat64(3, {st_mode=S_IFREG|0666, st_size=2143, ...}) = 0
read(3, "MAP\r\nIMAGETYPE PNG24\r\nEXTEN"..., 8192) = 2143
read(3, "", 4096) = 0
open("/usr/local/share/proj/epsg", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=376784, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40015000
read(4, "# Anguilla 1957 / British West I"..., 4096) = 4096
read(4, " +y_0=0 +ellps=clrk66 +units=m +"..., 4096) = 4096
read(4, "vak +lat_0=49.5 +lon_0=24.833333"..., 4096) = 4096
read(4, "1,-108.32,-62.39,0,0,0,0 +units="..., 4096) = 4096
read(4, "666667 +k=1.000000 +x_0=400000 +"..., 4096) = 4096
read(4, "=6356751.689189189 +towgs84=-199"..., 4096) = 4096
read(4, "efs no_defs <>\n# Sierra Leone 1"..., 4096) = 4096
close(4) = 0
munmap(0x40015000, 4096) = 0
brk(0x8124000) = 0x8124000
read(4, "<2193> +proj=tmerc +lat_0=0 +lon"..., 4096) = 4096
read(4, "83 +to_meter=0.3048 +no_defs no"..., 4096) = 4096
read(4, "\n# NAD83 / Idaho East (ftUS)\n<22"..., 4096) = 4096
read(4, " <>\n# NAD83 / New York East (ftU"..., 4096) = 4096
read(4, "33 +lat_2=28.38333333333333 +lat"..., 4096) = 4096
read(4, "84 +units=m +no_defs no_defs <>"..., 4096) = 4096
read(4, "755.288157528 +units=m +no_defs "..., 4096) = 4096
read(4, "0=37500000 +y_0=0 +a=6378140 +b="..., 4096) = 4096
read(4, "+units=m +no_defs no_defs <>\n# "..., 4096) = 4096
read(4, "-Kruger zone 32\n<2408> +proj=tme"..., 4096) = 4096
read(4, "llps=krass +units=m +no_defs no"..., 4096) = 4096
read(4, "999900 +x_0=0 +y_0=0 +ellps=GRS8"..., 4096) = 4096
read(4, "95 / Gauss-Kruger CM 147E\n<2484>"..., 4096) = 4096
read(4, "=0 +lon_0=123 +k=1.000000 +x_0=5"..., 4096) = 4096
read(4, "+x_0=21500000 +y_0=0 +ellps=kras"..., 4096) = 4096
read(4, " 3-degree Gauss-Kruger zone 46\n<"..., 4096) = 4096
read(4, "9 +k=1.000000 +x_0=500000 +y_0=0"..., 4096) = 4096
read(4, "14> +proj=tmerc +lat_0=0 +lon_0="..., 4096) = 4096
read(4, "defs no_defs <>\n# Pulkovo 1942 "..., 4096) = 4096
read(4, "tmerc +lat_0=0 +lon_0=93 +k=1.00"..., 4096) = 4096
read(4, "00 +y_0=0 +ellps=krass +units=m "..., 4096) = 4096
read(4, "j=tmerc +lat_0=0 +lon_0=72 +k=1."..., 4096) = 4096
read(4, "s=m +no_defs no_defs <>\n# Pulko"..., 4096) = 4096
read(4, "m +no_defs no_defs <>\n# NAD83(H"..., 4096) = 4096
read(4, "t\n<2787> +proj=tmerc +lat_0=41.6"..., 4096) = 4096
read(4, "at_0=44.78333333333333 +lon_0=-8"..., 4096) = 4096
read(4, "4=0,0,0,0,0,0,0 +units=m +no_def"..., 4096) = 4096
read(4, "at_1=27.83333333333333 +lat_2=26"..., 4096) = 4096
read(4, "a Central (ft)\n<2868> +proj=tmer"..., 4096) = 4096
read(4, "efs <>\n# NAD83(HARN) / Georgia W"..., 4096) = 4096
read(4, "000 +y_0=0 +ellps=GRS80 +towgs84"..., 4096) = 4096
read(4, "o_meter=0.3048006096012192 +no_d"..., 4096) = 4096
read(4, "_0=0.1166666666666667 +lon_0=50."..., 4096) = 4096
read(4, " +proj=utm +zone=49 +a=6377276.3"..., 4096) = 4096
read(4, "+proj=longlat +ellps=clrk80 +no_"..., 4096) = 4096
read(4, "nsua\n<4128> +proj=longlat +ellps"..., 4096) = 4096
read(4, ".689189189 +no_defs no_defs <>\n"..., 4096) = 4096
read(4, "\n<4229> +proj=longlat +ellps=hel"..., 4096) = 4096
read(4, "nglat +ellps=airy +no_defs no_d"..., 4096) = 4096
close(4) = 0
brk(0x813a000) = 0x813a000
close(4) = 0
brk(0x8150000) = 0x8150000
close(4) = 0
brk(0x8166000) = 0x8166000
close(4) = 0
close(3) = 0
open("/usr/local/lib", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = 3
fstat64(3, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
getdents64(0x3, 0x8161a00, 0x1000, 0) = 560
getdents64(0x3, 0x8161a00, 0x1000, 0) = 0
close(3) = 0
close(3) = 0
open("/lib/mmx/avgridio.dll", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/mmx", 0xbfffd7f0) = -1 ENOENT (No such file or directory)
open("/lib/avgridio.dll", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/mmx/avgridio.dll", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/mmx", 0xbfffd7f0) = -1 ENOENT (No such file or directory)
open("/usr/lib/avgridio.dll", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib", {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0
close(3) = 0
open("/lib/aigridio.dll", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/aigridio.dll", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/map/html/tutorial/symbols/symbols35.sym", O_RDONLY) = 3
ioctl(3, SNDCTL_TMR_TIMEBASE, 0xbfffdc20) = -1 ENOTTY (Inappropriate ioctl for device)
fstat64(3, {st_mode=S_IFREG|0666, st_size=1166, ...}) = 0
read(3, "# 1\nSymbol \nName \'tent\'\nType VEC"..., 8192) = 1166
read(3, "", 8192) = 0
ioctl(3, SNDCTL_TMR_TIMEBASE, 0xbfffdbe0) = -1 ENOTTY (Inappropriate ioctl for device)
close(3) = 0
open("/home/map/html/tutorial/fonts/fonts.list", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0666, st_size=1567, ...}) = 0
read(3, "andale-mono "..., 4096) = 1567
close(3) = 0
brk(0x816c000) = 0x816c000
brk(0x816e000) = 0x816e000
brk(0x816f000) = 0x816f000
brk(0x8170000) = 0x8170000
brk(0x8171000) = 0x8171000
brk(0x8172000) = 0x8172000
brk(0x8173000) = 0x8173000
brk(0x8174000) = 0x8174000
brk(0x8175000) = 0x8175000
brk(0x8176000) = 0x8176000
brk(0x8177000) = 0x8177000
brk(0x8178000) = 0x8178000
brk(0x8179000) = 0x8179000
brk(0x817a000) = 0x817a000
brk(0x817b000) = 0x817b000
brk(0x817c000) = 0x817c000
brk(0x817d000) = 0x817d000
brk(0x817e000) = 0x817e000
brk(0x817f000) = 0x817f000
brk(0x8180000) = 0x8180000
brk(0x8181000) = 0x8181000
brk(0x8182000) = 0x8182000
brk(0x8183000) = 0x8183000
brk(0x8184000) = 0x8184000
brk(0x8185000) = 0x8185000
brk(0x8186000) = 0x8186000
brk(0x8187000) = 0x8187000
brk(0x8188000) = 0x8188000
brk(0x8189000) = 0x8189000
brk(0x818a000) = 0x818a000
brk(0x818b000) = 0x818b000
brk(0x818c000) = 0x818c000
brk(0x818d000) = 0x818d000
brk(0x818e000) = 0x818e000
brk(0x818f000) = 0x818f000
brk(0x8190000) = 0x8190000
brk(0x8191000) = 0x8191000
brk(0x8192000) = 0x8192000
brk(0x8193000) = 0x8193000
brk(0x8194000) = 0x8194000
brk(0x8195000) = 0x8195000
brk(0x8196000) = 0x8196000
brk(0x8197000) = 0x8197000
brk(0x8198000) = 0x8198000
brk(0x8199000) = 0x8199000
brk(0x819a000) = 0x819a000
brk(0x819b000) = 0x819b000
brk(0x819c000) = 0x819c000
brk(0x819d000) = 0x819d000
brk(0x819e000) = 0x819e000
brk(0x819f000) = 0x819f000
brk(0x81a0000) = 0x81a0000
brk(0x81a1000) = 0x81a1000
brk(0x81a2000) = 0x81a2000
brk(0x81a3000) = 0x81a3000
brk(0x81a4000) = 0x81a4000
brk(0x81a5000) = 0x81a5000
brk(0x81a6000) = 0x81a6000
brk(0x81a7000) = 0x81a7000
brk(0x81a8000) = 0x81a8000
brk(0x81a9000) = 0x81a9000
brk(0x81aa000) = 0x81aa000
brk(0x81ab000) = 0x81ab000
brk(0x81ac000) = 0x81ac000
brk(0x81ad000) = 0x81ad000
brk(0x81ae000) = 0x81ae000
brk(0x81af000) = 0x81af000
brk(0x81b0000) = 0x81b0000
brk(0x81b1000) = 0x81b1000
brk(0x81b2000) = 0x81b2000
brk(0x81b3000) = 0x81b3000
brk(0x81b4000) = 0x81b4000
brk(0x81b5000) = 0x81b5000
brk(0x81b6000) = 0x81b6000
brk(0x81b7000) = 0x81b7000
brk(0x81b8000) = 0x81b8000
brk(0x81b9000) = 0x81b9000
brk(0x81ba000) = 0x81ba000
brk(0x81bb000) = 0x81bb000
brk(0x81bc000) = 0x81bc000
brk(0x81bd000) = 0x81bd000
brk(0x81be000) = 0x81be000
brk(0x81bf000) = 0x81bf000
brk(0x81c0000) = 0x81c0000
brk(0x81c1000) = 0x81c1000
brk(0x81c2000) = 0x81c2000
brk(0x81c3000) = 0x81c3000
brk(0x81c4000) = 0x81c4000
brk(0x81c5000) = 0x81c5000
brk(0x81c6000) = 0x81c6000
brk(0x81c7000) = 0x81c7000
brk(0x81c8000) = 0x81c8000
brk(0x81c9000) = 0x81c9000
brk(0x81ca000) = 0x81ca000
brk(0x81cb000) = 0x81cb000
brk(0x81cc000) = 0x81cc000
brk(0x81cd000) = 0x81cd000
brk(0x81ce000) = 0x81ce000
brk(0x81cf000) = 0x81cf000
brk(0x81d0000) = 0x81d0000
brk(0x81d1000) = 0x81d1000
brk(0x81d2000) = 0x81d2000
brk(0x81d3000) = 0x81d3000
brk(0x81d4000) = 0x81d4000
brk(0x81d5000) = 0x81d5000
brk(0x81d6000) = 0x81d6000
brk(0x81d7000) = 0x81d7000
brk(0x81d8000) = 0x81d8000
brk(0x81d9000) = 0x81d9000
brk(0x81da000) = 0x81da000
brk(0x81db000) = 0x81db000
brk(0x81dc000) = 0x81dc000
brk(0x81dd000) = 0x81dd000
brk(0x81de000) = 0x81de000
brk(0x81df000) = 0x81df000
brk(0x81e0000) = 0x81e0000
brk(0x81e1000) = 0x81e1000
brk(0x81e2000) = 0x81e2000
brk(0x81e3000) = 0x81e3000
brk(0x81e4000) = 0x81e4000
brk(0x81e5000) = 0x81e5000
brk(0x81e6000) = 0x81e6000
brk(0x81e7000) = 0x81e7000
brk(0x81e8000) = 0x81e8000
brk(0x81e9000) = 0x81e9000
brk(0x81ea000) = 0x81ea000
brk(0x81eb000) = 0x81eb000
brk(0x81ec000) = 0x81ec000
brk(0x81ed000) = 0x81ed000
brk(0x81ee000) = 0x81ee000
brk(0x81ef000) = 0x81ef000
brk(0x81f0000) = 0x81f0000
brk(0x81f1000) = 0x81f1000
brk(0x81f2000) = 0x81f2000
brk(0x81f3000) = 0x81f3000
brk(0x81f4000) = 0x81f4000
brk(0x81f5000) = 0x81f5000
brk(0x81f6000) = 0x81f6000
brk(0x81f7000) = 0x81f7000
brk(0x81f8000) = 0x81f8000
brk(0x81f9000) = 0x81f9000
brk(0x81fa000) = 0x81fa000
brk(0x81fb000) = 0x81fb000
brk(0x81fc000) = 0x81fc000
brk(0x81fd000) = 0x81fd000
brk(0x81fe000) = 0x81fe000
brk(0x81ff000) = 0x81ff000
brk(0x8200000) = 0x8200000
brk(0x8201000) = 0x8201000
brk(0x8202000) = 0x8202000
open("/home/map/html/tutorial/data/raster/mod09a12003161_ugl_ll_idxa.tif", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0666, st_size=6057262, ...}) = 0
read(3, "II*\0(e\\\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 4096) = 4096
close(3) = 0
stat64("/home/map/html/tutorial/data/raster/mod09a12003161_ugl_ll_idxa.tif", {st_mode=S_IFREG|0666, st_size=6057262, ...}) = 0
_llseek(3, 0, [0], SEEK_SET) = 0
open("/home/map/html/tutorial/data/raster/mod09a12003161_ugl_ll_idxa.tif", O_RDONLY|O_LARGEFILE) = 4
read(4, "II*\0(e\\\0", 8) = 8
_llseek(4, 6055208, [6055208], SEEK_SET) = 0
read(4, "\21\0", 2) = 2
read(4, "\376\0\4\0\1\0\0\0\0\0\0\0\0\1\3\0\1\0\0\0\230\r\0\0\1"..., 204) = 204
read(4, "\0\0\0\0", 4) = 4
--- SIGSEGV (Segmentation fault) ---
+++ killed by SIGSEGV +++
--=====================_715552250==_--
