RES: [Mapserver-users] Dynamic creation of shapefiles ...
Murilo Lacerda Yoshida
murilo.yoshida at agx.com.br
Thu Feb 5 16:28:46 EST 2004
Sorry for not posting the email to the list...
The shapefile is created, but I don't know how to check if it is
right. The only way I know to do this is displaying it on the
application, but it is not working. The dbf file is right.
I have another doubt. How do I know the minscale and the maxscale of a
shapefile created dynamically? I was thinking that this could be the
problem, so I changed this settings to a great scale (2+001 -> minscale
and 2+100 -> maxscale). I don't know, but I think that this values are
big...
Thanks,
Murilo
-----Mensagem original-----
De: Lowell Filak [mailto:lfilak at medinaco.org]
Enviada em: quinta-feira, 5 de fevereiro de 2004 19:21
Para: Murilo Lacerda Yoshida; mapserver-users at lists.gis.umn.edu
Assunto: RES: [Mapserver-users] Dynamic creation of shapefiles ...
I don't readily see anything but I'm not familiar with all the methods
your using so I'm forwarding this to the list.
Do you already have logging turned on or do you know for certain that
the shapefile is created successfully?
Lowell
The following message was sent by "Murilo Lacerda Yoshida"
<murilo.yoshida at agx.com.br> on Thu, 5 Feb 2004 18:54:49 -0200.
> This is the function I use to do the shapefile...
> function fazerShape()
> $shape = ms_newShapefileObj($this->path_to_data .
> $this->shapeFile, MS_SHP_POLYGON);
> $def = array( array("ID", "N", 5, 0), array("NOME", "C",
> 128), array("PATH", "C", 1024) );
> $objDbf = dbase_create($this->path_to_data .
> $this->shapeFile . ".dbf", $def);
> if ($objDbf !== false)
> $k = 0;
> foreach($this->talhao as $chave=>$valor)
> $objShape =
> ms_newShapeObj(MS_SHAPE_POLYGON);
> $objLine = ms_newLineObj();
> for ($i = 0; $i <
> $this->maximos[$chave]; $i++)
> $lat = $this->lat[$chave][$i];
> $long = $this->long[$chave][$i];
> if ($lat > $this->maxY)
> $this->maxY = $lat;
> if ($lat < $this->minY)
> $this->minY = $lat;
> if ($long > $this->maxX)
> $this->maxX = $long;
> if ($long < $this->minX)
> $this->minX = $long;
> $objLine->addXY($lat, $long);
> $lat = $this->lat[$chave][0];
> $long = $this->long[$chave][0];
> $objShape->add($objLine);
> $objLine->free();
> $shape->addShape($objShape);
> $objShape->free();
> $k++;
> $reg = array($k, $this->talhao[$chave],
> $this->path[$chave]);
> dbase_add_record($objDbf, $reg);
> $shape->free();
> dbase_close($objDbf);
> This is the one where I try to add all the points to one line and then
> add the line to the shape and then the shape to the shapefile ...
> Enviada em: quinta-feira, 5 de fevereiro de 2004 18:43
> Assunto: Re: [Mapserver-users] Dynamic creation of shapefiles ...
> You may want to include some of your code, as the method you are using
> should work.
> Lowell
> <murilo.yoshida at agx.com.br> on Thu, 5 Feb 2004 18:10:26 -0200.
> > Hi all,
> > I am trying to create dynamically a shapefile, with polygon
shapes,
> > but I am having trouble to do it.
> > If I understood the documentation, I have to do several lines with
> the
> > points that I have, and add one by one to the shape object, and then
> add
> > the shape object to the shapefile, is that correct?
> > I tried this way, but it didn't work. SO I tried to do a line with
> all
> > my points and then add this line to my shape object, and then add
this
> > shape object to the shapefile object. Still don't work.
> > Am I doing something wrong? I saw once a example at the mapserver
> wiki
> > about this, but I couldn't find it again.
> > Thanks in advance,
> > Murilo
