[Mapserver-users] MAp server dont show the images (png)
Pericles Nacionales
nacional at cbs.umn.edu
Thu Feb 5 16:33:16 EST 2004
Replace <input type="hidden" name="map_web_imageurl"
value="http://127.0.0.1/tmp"> with <input type="hidden"
value="/tmp/">. Note the extra slash after "tmp". Since you're using
MapServer 4.0.1, you'll run into other problems making the demo for
version 3.5 working. Have the MapServer 4 mapfile reference handy:
http://mapserver.gis.umn.edu/doc40/mapfile-reference.html
Other references, including Steve Lime's MapServer 4 demo, are at
http://mapserver.gis.umn.edu/doc.html.
Good luck!
-Perry
On Thu, 5 Feb 2004, david roguin wrote:
> Hi guys, i have a problem.
> I compile MapServer 4.01 without any problems
> but when i try to see the Demo itasca3.5 i can NOT see any image.
> I changed every thing to png, but i didn't work wither.
> here it is the demo_init.html
> <input type="hidden" name="map" value="/home/david/dev/www/itasca/demo.map">
> <input type="hidden" name="layer" value="lakespy2">
> <input type="hidden" name="layer" value="dlgstln2">
> <input type="hidden" name="zoomsize" value=2>
> <input type="hidden" name="program" value="/cgi-bin/mapserv">
> <input type="hidden" name="map_web_imagepath"
> value="/home/david/dev/www/tmp/">
> <input type="hidden" name="map_web_imageurl" value="http://127.0.0.1/tmp">
> ok. thanks a lot
> __________________________________________________________________
> David Roguin - Ingeniería de Producto - tel/fax (54) 11-4343-0070
> ASES Consulting - Av. Belgrano 510 piso 1 (C1092AAS)
> Ciudad Autónoma de Buenos Aires - Argentina
> Ases Consulting Site : http://www.ases.com.ar
> AVISO DE CONFIDENCIALIDAD. La información incluida en este e-mail está
> dirigida únicamente al destinatario. Puede contener información
> privilegiada, confidencial y que no debe ser revelada. Si ha recibido este
> e-mail por error, por favor no disemine, utilice, publique, distribuya,
> revele o copie esta comunicación de ningún modo. En cambio, por favor
> notifíquenos inmediatamente remitiéndonos este e-mail (incluso el mensaje
> original en su contestación), por tel / fax(54-11-4343-0070) y entonces
> elimine y deseche todas las copias de este e-mail. Gracias
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
