[Mapserver-users] Reprojection of shape file.
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 6 00:08:51 EST 2004
Jason M. Nielsen wrote:
> [root at vad3rZIM data]# cs2cs +proj=latlong +datum=NAD83 +to +proj=lcc
> +datum=NAD83 -r EOF
Jason,
I think I am answering something someone else has already answered ... damn
my non-linear mail reading. But I think there is an issue with the way
you are specifing the LCC projection in this cs2cs statement. You can use the
"-v" switch for cs2cs or proj to see what actual parameters are getting used
internally:
warmerda at gdal2200[123]% proj -v +proj=lcc +datum=NAD83
#Lambert Conformal Conic
# Conic, Sph&Ell
# lat_1= and lat_2= or lat_0
# +proj=lcc +datum=NAD83 +lat_1=33 +lat_2=45 +ellps=GRS80 +towgs84=0,0,0
As you can see, PROJ is using default standard parallels of 33N and 45N.
The LCC projection would also normally have a lat_0 and and lon_0 origin
which I assume is defaulting to 0dW, 0dN. Are you sure this is the
projection you wanted to define? I would suggest you define all the LCC
arguments explicitly.
You might want to see:
http://www.remotesensing.org/geotiff/proj_list/lambert_conic_conformal_2sp.html
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
