[Mapserver-users] pgojection & swf & multiple character set support question
Pericles S. Nacionales nacional at cbs.umn.edu
Fri Feb 6 00:55:11 EST 2004
Wei,
1. Make sure you have the directory C:\Proj\Nad and in that directory a
file named "epsg".
2. The SWF format is beyond the scope of the tutorial (which is meant to
get you started with simple png/png24/gif output formats).  The flash
format requires a plugin and so can't be read directly by the browser.
If you want an example of a flash application, you need to look at
http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
3. Give us more detail here.  Show me your font list and a snippet of
your mapfile and maybe I can help.
-Perry
On Thu, 2004-02-05 at 21:25, Litao Wei wrote:
> Dear Sir,
> When I tried to finish the totutial, I have met some problems:
> 1. example that use PROJECTION didn't work well on my winxp box, and the screen showed:
>     msProcessProjection(): Projection library error. no system list, errno: 2
> 2.When using swf format for output I would received an error on my browser:
>     Content-type: text/html msBuildPath: Unable to access file.
> 3.Could mapserver support other chacter set for output(i.e. the label)? I am a chinese user, I hope to show the lebel on map by chinese, not by english word. When I try this, I would receive many strange character on browser.(I both try to use chinese fonts or westen fonts for the font attribute). I have heard the GD module can show correctly. So I think mapserver can show also, right? And what to do?
> I use windows xp and the mapserver I downloaded is the newest binary version of windows playform.
> Good Luck.
> Litao Wei
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
"He's no geek.His tan's too good." -Benjamin Choate
