[Mapserver-users] Question regarding connetion between mapserver and Arc SDE
RAJA RAMAN
kamma_raja at yahoo.com
Fri Feb 6 11:26:00 EST 2004
--0-2078703522-1076084760=:92716
Content-Type: text/plain; charset=us-ascii
Dear all,
I am trying to connect the arc SDE layer to mapserver and first i would like to know whether SDE is same as arcSDE or something else. I am trying to connect this through the oracle database.
Please find the attached code for the arcSDE layer in the map file which I have created. I am not able to see anything when I display this layer. any suggestions will be appreciated.
System setup:
Windows 2000 professional
Arc SDE 8.2
Oracle 9i
Mapserver 4.0
Coding:
LAYER
NAME "Bio2002"
STATUS ON
DATA "SDE.SDE.BIO2002_POLYGON,Shape"
TYPE POLYGON
CONNECTIONTYPE SDE
CONNECTION "pc212614,esri_sde,Oracle,sde,arcims"
CLASSITEM "ID"
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TOLERANCEUNITS PIXELS
TEMPLATE "ttt.html"
CLASS
NAME "BIo2002"
SYMBOL 0
COLOR 254 228 141
OUTLINECOLOR 71 63 39
SIZE 1
MINSIZE 1
MAXSIZE 100
LABEL
TYPE TRUETYPE
FONT "fritqat"
SIZE 8
MINSIZE 4
MAXSIZE 256
POSITION CC
OFFSET 0 0
ANGLE 0.000000
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
ANTIALIAS TRUE
PARTIALS TRUE
FORCE FALSE
END
END
END
I am little bit confused about the data and the connection parameters......can anybody clearly explain how to specify the data in DATA
Thank you in advance
rajaraman kamma
ADDRESSES
RAJA RAMAN KAMMA
PFAFFELWELDRING, 44D,206,70569 STUTTGART,GERMANY
Cell numbers: Home: 0711-9984931 Mobile: 0049-1797785507
Home Page:http://www.geocities.com/kamma_raja/
Photos: http://rajaraman.fotopic.net
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
Content-Type: text/html; charset=us-ascii
<DIV>
<DIV>Dear all,</DIV>
<DIV> </DIV>
<DIV>I am trying to connect the arc SDE layer to mapserver and first i would like to know whether SDE is same as arcSDE or something else. I am trying to connect this through the oracle database. </DIV>
<DIV> </DIV>
<DIV>Please find the attached code for the arcSDE layer in the map file which I have created. I am not able to see anything when I display this layer. any suggestions will be appreciated.</DIV>
<DIV> </DIV>
<DIV><STRONG>System setup:</STRONG></DIV>
<DIV> </DIV>
<DIV>Windows 2000 professional</DIV>
<DIV>Arc SDE 8.2</DIV>
<DIV>Oracle 9i</DIV>
<DIV>Mapserver 4.0</DIV>
<DIV> </DIV>
<DIV><STRONG>Coding:</STRONG></DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>LAYER<BR> NAME "Bio2002"<BR> STATUS ON<BR> DATA "SDE.SDE.BIO2002_POLYGON,Shape"<BR> TYPE POLYGON<BR> CONNECTIONTYPE SDE<BR> CONNECTION "pc212614,esri_sde,Oracle,sde,arcims"<BR> CLASSITEM "ID"<BR> UNITS METERS<BR> SIZEUNITS PIXELS<BR> TOLERANCE 3<BR> TOLERANCEUNITS PIXELS<BR> TEMPLATE "ttt.html"<BR> CLASS<BR> NAME "BIo2002"<BR> SYMBOL 0<BR> COLOR 254 228 141<BR> OUTLINECOLOR 71 63 39<BR> SIZE 1<BR> MINSIZE 1<BR> MAXSIZE 100<BR> LABEL<BR> TYPE
TRUETYPE<BR> FONT "fritqat"<BR> SIZE 8<BR> MINSIZE 4<BR> MAXSIZE 256<BR> POSITION CC<BR> OFFSET 0 0 <BR> ANGLE 0.000000<BR> BUFFER 0<BR> MINDISTANCE -1<BR> MINFEATURESIZE -1<BR> COLOR 0 0 0<BR> ANTIALIAS TRUE<BR> PARTIALS TRUE<BR> FORCE FALSE<BR> END<BR> END<BR> END<BR></DIV>
<DIV>I am little bit confused about the data and the connection parameters......can anybody clearly explain how to specify the data in DATA </DIV>
<DIV><BR>Thank you in advance</DIV>
<DIV>rajaraman kamma</DIV>
<DIV> </DIV></DIV><BR><BR><DIV>
<DIV>
<DIV>
<DIV>
<P><STRONG>ADDRESSES </STRONG></P>
<P>RAJA RAMAN KAMMA <BR>PFAFFELWELDRING, 44D,206,70569 STUTTGART,GERMANY <BR>Cell numbers: Home: 0711-9984931 Mobile: 0049-1797785507 <BR>Home Page:<U>http://www.geocities.com/kamma_raja/</U> <BR>Photos: <A href="http://rajaraman.fotopic.net/show_collection.php?offset=1&id=94525">http://rajaraman.fotopic.net</A></P></DIV></DIV></DIV></DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
Yahoo! Finance: <a href="http://us.rd.yahoo.com/evt=22055/*http://taxes.yahoo.com/filing.html">Get your refund fast by filing online</a>
--0-2078703522-1076084760=:92716--
