[Mapserver-users] wms and projections
Charlton Purvis cpurvis at asg.sc.edu
Fri Feb 6 15:17:38 EST 2004
Hi, Amit:
I have found that the MIN/MAX SCALES don't necessarily match up
precisely between regular mapserver cgi calls and WMS calls.
So I'd play around w/ your MINSCALE since that made a difference w/ your
cgi results.  Make it something ridiculous to make sure it includes
everything.
Charlton
> -----Original Message-----
> From: Amit S BEHERE [mailto:abehere at cs.ucsd.edu]
> Sent: Friday, February 06, 2004 2:38 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] wms and projections
> Hi all,
> This is an extension of the question I had posted previously regarding
> seeing only one point on the map. I had taken example1-1.map from the
> tutorial and modified it to display my shapefile. However I was seeing
> only one tree when I should have been seeing a whole bunch. Thanks to
> David I was able to fix that (I needed to set MINSCALE, athough I
don't
> know why yet?) and could see the whole set of trees.
> Now I have converted that mapfile to serve as a WMS service by adding
the
> appropriate wms tags in the mapfile. I am getting the capabilites back
> correctly. However when I use the OGIS GetMap request I again see just
one
> tree.
http://pune/mapserver/mapserv.exe?map=/MSTutorial/testwms.map&request=ge
tm
> ap&version=1.1
> However if I view the same file i.e testwms.map using the regular
> mapserver interface i.e using the command
> http://pune/mapserver/mapserv.exe?map=/MSTutorial/testwms.map&mode=map
> I see the whole set again. So basically I see just one tree if I give
the
> OGIS getmap url and a whole set of trees when I give the regular
> mapserver url. Any one encountered similar problems or any idea why
this
> is happening
> Here is my map file
> MAP
>   NAME 	     demoservice
>   IMAGETYPE      PNG
>   EXTENT         385538 3761010 391329 3764477
>   UNITS	     METERS
>   SIZE           600 600
>   SHAPEPATH      "data"
>   IMAGECOLOR     255 255 255
> PROJECTION
>   "init=epsg:26911"
> END
> WEB
>    IMAGEPATH "c:\itasca\tmp\"
>    IMAGEURL "/tmp/"
>    MINSCALE 50000         #with this enabled, produces image with all
> points
>    #MAXSCALE 15500000       #see 'with_scale_restrictions.png'
>    METADATA
> 	"wms_title"			"WMS Demo Server"
> 	"wms_onlineresource"
> "http://pune/mapserver/mapserv.exe?map=/MSTutorial/testwms.map&"
> 	"wms_srs"			"epsg:26911"
>    END
> END
> SYMBOL
>  NAME 'circle'
>  TYPE ELLIPSE
>  POINTS 1 1 END
>  FILLED TRUE
> END
> LAYER
>    NAME  trees
>    DATA  vernon_trees
>    STATUS  DEFAULT
>    TYPE POINT
>    LABELITEM "TREEID"
>    CLASS
>      COLOR        0 0 0
>       SYMBOL 'circle'
>       SIZE  6
>    END
> PROJECTION
>   "init=epsg:26911"
> END
>    METADATA
> 	"wms_extent"		"385538 3761010 391329 3764477"ho
>    END
>  END #  layer ends here
> END # end of map file/object
> Amit Behere.
> UCSD.
> "Technology doesn't make your life more difficult or easy, it just
changes
> the rules"......Vishwanathan Anand
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
