[Mapserver-users] WMS Solution: PHP/Mapscript vs CGI?
Bart van den Eijnden
bartvde at xs4all.nl
Sat Feb 7 11:42:43 EST 2004
Hi Pierre,
we use Mapserver CGI (as a WMS Server) on our data, and then PHP/Mapscript
as the WMS client.
You can perhaps have a look at Chameleon (www.maptools.org), the same
approach can be used in Chameleon.
Best regards,
Bart
On Sat, 07 Feb 2004 23:22:04 +0800, peng zhang <pierrezhang at hotmail.com>
wrote:
> list:
> My application should be WMS compliant, both server and client. Obviously
> Mapserver CGI is good choice, simple and powerful for WMS server.
> actually I
> already set it up, and it works well. But I also need to the
> functionility to
> intergrate layers from other WMS-compliant instance. One approach is to
> add new
> layers dynamically, whose CONNECTIONTYPE should be WMS, to local mapfile
> (my
> local server as cascading WMS) when users choose layers from other WMS
> instance
> like Maplab's Mapbrowser.
> The problem is:
> It seems that with Mapserver CGI I cannt add new layers to mapfile
> on-the-fly.
> Is it right?
> If so, should I turn to PHP/Mapscript? But I didnt find any instance
> that use
> PHP/Mapscript as WMS server. Is there any tutorial, demo or how-to on
> set up WMS
> server by PHP/Mapscript?
> Thanks in advance!
> pierre
> Protect your PC - Click here for McAfee.com VirusScan Online
> _______________________________________________ Mapserver-users mailing
> list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
