[Mapserver-users] Mouse Over
Bart van den Eijnden
bartvde at xs4all.nl
Sat Feb 7 17:36:16 EST 2004
Hi Alex,
in Chameleon (www.maptools.org), which is based on PHP/Mapscript, there is
functionality for this. It is called the "MapTips" widget. In this widget
the approach you sketch is used (the image map approach). So if you want
to know about performance etc, try it out with Chameleon. I don't know
about the Mapplet XML approach, maybe somebody else can comment on this
one.
Best regards,
Bart
On Sat, 07 Feb 2004 21:27:36 +0100, Alexander Pucher
<pucher at atlas.gis.univie.ac.at> wrote:
> Hi,
> this questions comes up every now and then...
> What is the current status, if I want to include mouse over events with
> mapserver-php/mapscript. Suggestions of previous mails mentioned the
> "plain" image map solution, i.e. to generate an image map out of the
> geodata and overlay it over the rendered image.
> Are there some real-life examples for this?
> What might be the performance when using it with a ~3000 polygon (~150
> points each) layer?
> What about the mapplet XML approach. Is there some documentation
> available for this?
> Regards,
> alex.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
