[Mapserver-users] Rotating labels in point shapefile
Wim Blanken PI
wim.blanken at planet.nl
Mon Feb 9 10:33:31 EST 2004
This is a multi-part message in MIME format.
--Boundary_(ID_0Ko/nMQBgeY6KsuJ+rrJ/Q)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: 7BIT
Hello Valerio,
Take a look at the LABELANGLEITEM setting in the LAYER item.
The item is the column with the angle in degrees.
For example
LAYER.....
LABELANGLEITEM "DEGREES"
CLASS
LABEL
END
END
Regards,
Wim Blanken
GEON bv
The Netherlands
----- Original Message -----
To: mapserver-users at lists.gis.umn.edu
Sent: Monday, February 09, 2004 4:27 PM
Subject: [Mapserver-users] Rotating labels in point shapefile
Hello,
is it possible to rotate labels of a point shapefile depending on a database field which contains angle value?
Thanks
Valerio Noti
Content-type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 5.50.4134.600" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hello Valerio,</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV>
<DIV><FONT face=Arial size=2>Take a look at the LABELANGLEITEM setting in the
LAYER item.</FONT></DIV>
<DIV><FONT face=Arial size=2>The item is the column with the angle in
degrees.</FONT></DIV>
<DIV><FONT face=Arial size=2>For example</FONT></DIV>
<DIV><FONT face=Arial size=2>LAYER.....</FONT></DIV>
<DIV>LABELANGLEITEM "DEGREES"</DIV>
<DIV><FONT face=Arial size=2>CLASS</FONT></DIV>
<DIV><FONT face=Arial size=2>....</FONT></DIV>
<DIV><FONT face=Arial size=2>LABEL</FONT></DIV>
<DIV><FONT face=Arial size=2>......</FONT></DIV>
<DIV><FONT face=Arial size=2>END</FONT></DIV>
<DIV><FONT face=Arial size=2>.....</FONT></DIV>
<DIV><FONT face=Arial size=2>Regards,</FONT></DIV>
<DIV><FONT face=Arial size=2>Wim Blanken</FONT></DIV>
<DIV><FONT face=Arial size=2>GEON bv</FONT></DIV>
<DIV><FONT face=Arial size=2>The Netherlands</FONT></DIV>
<BLOCKQUOTE dir=ltr
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style="FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV
style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black"><B>From:</B>
<A title=noti at ciaoweb.it href="mailto:noti at ciaoweb.it">Valerio Noti</A> </DIV>
<DIV style="FONT: 10pt arial"><B>To:</B> <A
title=mapserver-users at lists.gis.umn.edu
href="mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.gis.umn.edu</A>
</DIV>
<DIV style="FONT: 10pt arial"><B>Sent:</B> Monday, February 09, 2004 4:27
PM</DIV>
<DIV style="FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] Rotating
labels in point shapefile</DIV>
<DIV><BR></DIV>
<DIV><FONT face=Arial size=2>Hello,</FONT></DIV>
<DIV><FONT face=Arial size=2>is it possible to rotate labels of a point
value?</FONT></DIV>
<DIV><FONT face=Arial size=2>Thanks</FONT></DIV>
<DIV><FONT face=Arial size=2>Valerio
Noti</FONT></DIV></BLOCKQUOTE></BODY></HTML>
--Boundary_(ID_0Ko/nMQBgeY6KsuJ+rrJ/Q)--
