[Mapserver-users] Windows XP
Wim Blanken PI
wim.blanken at planet.nl
Mon Feb 9 12:04:05 EST 2004
Hello Bobby,
Normally this is the result of an incomplete installation of mapserver.
Have you copied all of the required dll files (libraries) to the system32
directory of Windows XP?
You can check which dll files are missing if you execute mapserv.exe with
the following parametre.
mapserv.exe -v
Mapserver will complain telling you which dll is missing......
Regards,
Wim Blanken
GEON bv
The Netherlands
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 09, 2004 5:33 PM
Subject: [Mapserver-users] Windows XP
> I am trying to get the Demo working under Windows XP Professional. I get
> the following error message when I clcik on the SUBMIT Button:
> CGI Error
> The specified CGI application misbehaved by not returning a complete set
of
> HTTP headers. The headers it did return are:
> There is nothing output after .... The headers it did return are:
> Can Anyone help out please?
> Regards.
> Bobby.
> My Folder Configuration is as follows:
> C:\Intepub\wwwroot\CGI-BIN (virtual directory is called cgi-bin having
> execute permissions)
> \itasca (virtual directory is called itasca)
> \itasca\CVS
> \itasca\data
> \itasca\graphics
> \itasca\perl
> \itasca\symbol
> \itasca\*.html, demo.log, demo.map
> C:\Intepub\wwwroot\tmp (virtual directory is called tmp having write
> permissions)
> The changes I made are as follows
> THE DEMO_INIT.HTML FILE
> <html>
> <head><title>MapServer Demo Interface</title></head>
> <body bgcolor="#FFFFFF">
> <center><h2>MapServer Demo Interface</h2></center>
> <p><hr><p>
> Click on the initialize button to fire up the demo with 3 layers turned on
> will be accessible for browsing. The
> data are of Itasca County, MN and were derived, for the most part, from
USGS
> 1:24,000 quadrangles. Some things to note are:
> <form method=GET action="/cgi-bin/mapserv.exe">
> <input type="hidden" name="map"
value="c:\Inetpub\wwwroot\itasca\demo.map">
> <input type="hidden" name="layer" value="lakespy2">
> <input type="hidden" name="layer" value="dlgstln2">
> <input type="hidden" name="zoomsize" value=2>
> <input type="hidden" name="program"
> value="c:\Inetpub\wwwroot\cgi-bin\mapserv.exe">
> <!--<input type="hidden" name="program"
lue="/cgi-bin/mapserv.exe"> -->
> <input type="hidden" name="map_web_imagepath"
> value="C:\inetpub\wwwroot\tmp\">
> <input type="hidden" name="map_web_imageurl" value="/tmp/">
> <center><input type="submit" value="Initialize"></center>
> </form>
> <p><hr><p>
> </body></html>
> CHANGES MADE TO THE DEMO.MAP FILE
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://localhost/itasca/demo_init.html"
> _________________________________________________________________
> Choose now from 4 levels of MSN Hotmail Extra Storage - no more account
> overload! http://click.atdmt.com/AVE/go/onm00200362ave/direct/01/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
