Antw: Re: [Mapserver-users] MapScript Installation Problem
Thomas Lynen
Thomas.Lynen at regioit-aachen.de
Tue Feb 10 10:54:29 EST 2004
Hi Ed,
if the mapscript.dll would load another dll that is noch installed, "dependency walker" ( www.dependencywalker.com ) show me the missing dll's.
i don't found the ZLIB.dll on the machine but i found it on our HAHTSite MapXtreme Server.
But if i need this dll, why couldn't i download it from http://www2.dmsolutions.ca/mapserver/dl/ ?
Well, tomorrow i will test it and report the result here ( for other developer with the same problem )
i also test another php version if the zlib.dll don't solve the problem
Thank you very much for your help.
Have a nice evening! :-)
Greets
Thomas
>>> "Ed McNierney" <ed at topozone.com> 10.2.2004 16:33:16 >>>
Thomas -
You may be unable to load a DLL because *that DLL* loads another DLL at
runtime. I think the most commonly overlooked DLL in MapServer
installations is ZLIB.DLL - do you have it installed in the system path?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Thomas Lynen [mailto:Thomas.Lynen at regioit-aachen.de]
Sent: Tuesday, February 10, 2004 10:09 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Antw: Re: [Mapserver-users] MapScript Installation Problem
Thanks for the fast help, but i have still the same problem
i have load the mapscript_4.0.1.dll with "dependency walker" ( btw :
very good tool ) MPR.dll -> Warning: At least one module has an
unresolved import due to a missing export function in a delay-load
dependent module.
But i think it's not the problem.
If i try to load the php_GD2.dll with "dependency walker" the same
warning is displayed and the dl(php_GD2.dll) works fine.
My php.ini Settings
extension_dir = "c:\php\extensions\"
enable_dl = On
;extension=php_mapscript_4.0.1.dll <- only a comment
<HTML>
<BODY>
<?php
dl("php_mapscript_4.0.1.dll");
// dl ("php_gd2.dll");
phpinfo();
</BODY>
</HTML>
result :
Unable to load dynamic library
'C:/php/extensions/php_mapscript_4.0.1.dll'
the php_mapscript_4.0.1.dll and the php_GD2.dll are in the same
directory how can php found the php_GD2.dll and not the
php_mapscript_4.0.1.dll when the both are in the same directory ?
i guess its a version conflict with php
Use anyone MapServer/MapScript with a WA(M)P configuration an can tell
me which version of Apache/Php/Mapscript he use.
according to the homepage mapscript 4.0 is compatible with PHP 4.1.2 and
up (PHP 4.3.2 or more recent recommended) source :
http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html#example
regards
Thomas Lynen
>>> pagameba at magma.ca 10.2.2004 12:31:31 >>>
try setting extension_dir="c:\php\extensions"
if you set extension=php_mapscript_4.0.1.dll you may not need to set
enable_dl=On. enable_dl is enabling dynamic loading. If you leave the
extension out of php.ini and enable_dl=On then you can use dl(
'php_mapscript_4.0.1.dll' ); in your scripts to load mapscript. If you
add extension=php_mapscript_4.0.1.dll then you do not need to use dl in
your script and in fact it will cause an error.
the next thing to try is to get the dependency walker from
www.dependencywalker.com and run it on php_mapscript_4.0.1.dll, it will
tell you if all the dll dependencies can be found. Windows will
sometimes give you misleading error messages, like the extension can't
be found ... often this means that a dll the extension relies on can't
be found.
Cheers,
Paul
Thomas Lynen wrote:
> Hi all,
> yesterday i try to install the MapServer and MapScript.
> I install the Apache ( apache_1.3.28-win32-x86-no_src.exe ), PHP as
> CGI ( php-4.3.3-installer.exe ) and extract the MapServer Zip File (
mapserver-4.0.1-win32-php4.3.3.zip ) I follow the instructions in the
README.txt ( which was in the mapserver-4.0.1-win32-php4.3.3.zip ).
> I copy all dlls in the Windows/System32 directory ( pdflib.dll,
> libpq.dll, libcurl.dll, xerces-c_1_6_0.dll, gdal11.dll and all dlls
> from ECW_DLL.zip )
> Now, the readme say i must add the php_mapscript_4.0.1.dll as a php
extension.
> i change the php.ini
> extension_dir = "./extensions" ( i also try "./", "./extensions/" and
> "c:/php/" ) ...
> enable_dl = On ( can't be wrong )
> Of course i copy the MapScript Dll ( together with the php_proj.dll )
in the correct directory.
> I copy the php_mapscript_4.0.1.dll to c:\php\extensions\ but if a
start a php file like http://localhost/index.php a error orrcure because
they don't found the dll.
> Message : Unkown(): Unable to load dynamic library
'./extensions\php_mapscript_4.0.1.dll' - Das angegebene Modul wurde
nicht gefunden.
> I also test it with php_mapscript_36.dll Whe i add a other dll (
> php_gd2.dll ), this dll could be found.
> I don't compiled any files, i use the precompiled files.
> I have additionally read the
but i t was not realy helpful.
> I use Windows 2K with SP 3 and Windows XP with SP 1
> I hope someone could help me.
> regards
> Thomas Lynen
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
