[Mapserver-users] How to use mapserver to cascade arcims wms services
Bart van den Eijnden bartvde at xs4all.nl
Tue Feb 10 13:28:44 EST 2004
Hi Larry,
this is because Mapserver cannot reproject raster layers.
A WMS layer is treated as a RASTER layer, so it cannot be reprojected.
Only thing Mapserver can do is send the EPSG code in the WMS request to
the WMS it cascades. Maybe if you use EPSG:4326 the ArcIMS WMS won't
reproject?
Best regards,
Bart
On Tue, 10 Feb 2004 14:53:53 -0330, Larry Nolan <larrynolan at gov.nl.ca>
wrote:
> Thanks Bart,
>     It turns out that my problem is in my projection specification. If I
> put an espg:26721  it works fine but is projected incorrect.
> I'm trying to use a Transverse Mercator projection centered on 59.5
> degrees west with a false easting of 1000000 and a false northing of 0
> in NAD 27
> But for some reason mapserver or arcims reports an error.
> The projection string in the arcims axl file is:
>         <FEATURECOORDSYS
> string='PROJCS["NF_GNL1",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",1000000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-59.5],PARAMETER["Scale_Factor",0.998],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]'
> In Mapserver I am using:
> Projection
>     "proj=tmerc"
>     "lat_0=0.0"
>     "lon_0=-59.5"
>     "k=0.998"
>     "x_0=1000000.0"
>     "y_0=0.0"
>     "ellps=clrk66"
>     "units=m"
>     "no_defs"
> End
> Thanks.
> Larry Nolan
> GIS and Geoscience Data Management
> Geological Survey of Newfoundland and Labrador
> Department of Mines and Energy
> http://gis.geosurv.gov.nf.ca
> telephone 709-729-2168
> fax           709-729-4270
>>>> Bart van den Eijnden <bartvde at xs4all.nl> 02/07/04 01:24PM >>>
> Hi Larry,
> first of all I think your wms_name is invalid, because it contains a
> space. The wms_name is used to perform the WMS request. Secondly, you
> should use 1 wms_format instead of 2 formats separated by commas (does
> your ArcIMS server have a GIF license, if not use image/png).
> Here I have a working example (BTW I am using the ESRI WMS connector
> 0.0.6
> instead of the standard version delivered with ArcIMS 4):
> LAYER
>    CONNECTION
> "http://myserver/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?servicename=top50vector&SERVICE=WMS&VERSION=1.1.0&LAYERS=t50_vlakken_region&QUERY_LAYERS=t50_vlakken_region&FORMAT=image/png&transparent=true"
>    CONNECTIONTYPE WMS
>      METADATA
>        "wms_srs"	"EPSG:28992 EPSG:4326"
>        "wms_onlineresource"	"http://myserver/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?servicename=top50vector&"
>        "wms_stylelist"	""
>        "wms_name"	"top50vector_t50_vlakken_region"
>        "wms_title"	"top 50 vector"
>        "wms_style_default_title"	""
>        "wms_style_default_legendurl"	"0 0  "
>        "wms_server_version"	"1.1.0"
>        "wms_formatlist"	"image/jpeg,image/png"
>        "wms_format"	"image/png"
>        "wms_boundingbox"	"EPSG:28992 0 288007.5 288009 624000"
>        "wms_style"	"default"
>        "wms_latlonboundingbox"	"2.68506 49.54247 7.75847 54.61588"
>      END
>    NAME "top50vector_t50_vlakken_region"
>    PROJECTION
>      "init=epsg:28992"
>    END
>    SIZEUNITS PIXELS
>    STATUS ON
>    DUMP TRUE
>    MINSCALE 0
>    MAXSCALE 50000
>    TEMPLATE "blank.html"
>    TOLERANCE 0
>    TOLERANCEUNITS PIXELS
>    TYPE RASTER
>    UNITS METERS
> END
> Best regards,
> Bart
> On Fri, 06 Feb 2004 16:47:18 -0330, Larry Nolan <larrynolan at gov.nl.ca>
> wrote:
>> I have a group of geological surveys which have arcims web mapping
>> servers with tons of geological information. I would like to use
>> mapserver to act as a one stop connection to each of those servers in a
>> client. I have mapserver 4.0 working fine serving ogc wms map services.
>> Does anyone have the syntax to connect to an esri arcims service which
>> has the wms connector turned on.
>> I get a a general service exception when I try to connect to this layer.
>>  LAYER
>>   NAME "NAD27LandBase"
>>   TYPE RASTER
>>   STATUS ON
>>   CONNECTION
>> "http://gis.geosurv.gov.nf.ca/servlet/com.esri.wms.Esrimap?servicename=NAD27_Basemap"
>>   CONNECTIONTYPE WMS
>>   METADATA
>>      "wms_name"            "Base Map"
>>      "wms_formatlist"      "image/gif,image/png,image/jpeg,image/wbmp"
>>      "wms_format"          "image/gif,image/png"
>>   END
>>   PROJECTION
>>     "proj=tmerc"
>>     "lat_0=0.0"
>>     "lon_0=-59.5"
>>     "k=0.998"
>>     "x_0=0.0"
>>     "y_0=1000000.0"
>>     "ellps=clrk66"
>>     "units=m"
>>     "no_defs"
>>   END
>>  END
>> thanks
>> Larry Nolan
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
