[Mapserver-users] new to mapserver - installation help
Michael Darweesh
mjd at mars.asu.edu
Tue Feb 10 15:32:47 EST 2004
Double-check the permissions and file information on your mapserver
executable. the Redhat http doesn't like executing cgi where the
executable is owned by root. Though, I can't be sure that's your
installation's problem without more information. What does your
/var/www/http/error_log say when you try to run as cgi?
-Mike
arun at activeengineer.com wrote:
>I am trying to install on Redhat. If I compile with GD and Freetype, it tests
>fine from web browser. But thn if I add proj or gdal, it compiles fine and
>tests of from the command line but errors out ( Internal Server error 500 )
>from the web browser. File permissions are identical in both cases. CAn any one
>throw some light please?
>Arun
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
