[Mapserver-users] Point display question
Amit S BEHERE
abehere at cs.ucsd.edu
Tue Feb 10 17:08:26 EST 2004
Hi all,
I think I found out the answer to my problem. I need to create a ttf file
from my .png file and use that as a font in my label. Isn't that right ?
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just changes
the rules"......Vishwanathan Anand
On Tue, 10 Feb 2004, Amit S BEHERE wrote:
> Hi all,
> this is in continuation of the question I asked previously (below)
> regarding rotating symbols. I understand that you cannot rotate symbols.
> So from the response I received (below) my guess is
> I need to associate the symbol (my .png file) with a label
> and rotate the label.
> I have tried doing that but have so far been unsuccessful. My map file is
> below I have hilited the parts that I think need change after which things
> should work.
> MAP
> IMAGETYPE PNG
> EXTENT -118.23 33.99 -118.22 34.00
> SIZE 500 500
> SHAPEPATH "data"
> STATUS ON
> UNITS METERS
> TRANSPARENT ON
> # *********************START****************************************
> SYMBOL
> Name 'mysymbol'
> TYPE PIXMAP
> IMAGE "c:\mstutorial\images\trial.png"
> END
> This symbol (or more correctly the trial.png file I guess) needs to be
> associated with a label so that it can be rotated
> # ********************END***********************************************
> LAYER
> NAME vernon_sewers
> DATA vernon_sewerstructures
> #***********************START******************************************
> LABELITEM "????????"
> LABELANGLEITEM "Angle"
> I do not understand what to put in LABELITEM field. I think I need to
> associate my labelitem field with my .png file
> By the way there is nothing in the database (i.e the .dbf file) that
> refers to my .png file.
> **********************END************************************************************
> STATUS DEFAULT
> TYPE POINT
> CLASS
> COLOR 0 0 0
> SYMBOL 'mysymbol' # THIS LINE NEEDS TO GO.
> # ********************START***********************************
> LABEL
> There is some code here too that needs to be added THAT ACTUALLY DISPLAYS
> THE LABEL. I do not know what.
> END
> #*******************END***********************************
> SIZE 6
> END
> END
> END
> At the moment you can't rotate symbols. You can rotate labels though so
> you could use a symbol ttf file for "symbols" and then use the
> LABELANGLEITEM property to rotate things feature-by-feature. I know
> folks are doing this with weather symbols like wind barbs and it works
> great.
> Steve
> >>> Amit S BEHERE <abehere at cs.ucsd.edu> 02/04/04 7:08 PM >>>
> Hi all,
> I have a mapfile that shows points on a map using a symbol. The points
> are
> in a shapfile which among other things has a field for the rotation
> angle
> for the symbol (i.e the dbf database associated with the shapefile has a
> column for rotation angle). Is there a way by which I could display the
> symbol rotated at the angle given in the table.
> Here is my layer definition:
> LAYER
> NAME "sewerstructures"
> TITLEINDEX vernon_global_index
> TITLEITEM FILES
> CLASSITEM "Style"
> DATA "sewerstructures"
> STATUS ON
> TYPE POINT
> MAXSCALE 32000
> MINSCALE 1
> CLASS
> EXPRESSION ('[STYLE]' eq 'Manhole-Vernon')
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> size 9
> symbol 1
> END
> END
> Amit Behere.
> UCSD.
> changes
> Amit Behere.
> UCSD.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
