[Mapserver-users] new to mapserver - installation help
Till Adams adams at terrestris.de
Wed Feb 11 02:51:04 EST 2004
Dear Arun,
sounds like your mapserv doesn ot find all libraries. Set the lib path
in the file "ld.so.conf" (normally in /etc/)
add:
/usr/local/lib
in there OR try the command:
/sbin/ldconfig /usr/local/lib -v
as root. You have to do the last every time you reboot your server,
Till
arun at activeengineer.com schrieb:
> I am trying to install on Redhat. If I compile with GD and Freetype, it tests
> fine from web browser. But thn if I add proj or gdal, it compiles fine and
> tests of from the command line but errors out ( Internal Server error 500 )
> from the web browser. File permissions are identical in both cases. CAn any one
> throw some light please?
> Arun
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
NEU +++ NEU +++ NEU +++ NEU
    AveiN! ist Open Source
Lizensiert unter der GNU GPL
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
