[Mapserver-users] WMS client and re-projection of WMS layers
Armin Burger
armin.burger at gmx.net
Wed Feb 11 10:41:08 EST 2004
This is a message in MIME format. The first part should be readable text,
while the remaining parts are likely unreadable without MIME-aware tools.
--AKMAILBOUNDARY
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
Hi everybody,
I was trying to load WMS layer (from an Esri ArcIMS server) into a MapServ=
er application using MapServer as WMS Client. The reference system of the =
WMS layer is lat/lon (WGS84), the reference system of the map is in a Lamb=
ert Azimuthal Equal Area projection. Therefore the WMS layer had to be re-=
projected to the main projection defined in the MAP tag. A snippet of the =
map file is:
MAP
=2E..
PROJECTION
"proj=3Dlaea"=20=20=20
"lat_0=3D48.000000"
"lon_0=3D9.000000"
"x_0=3D0.000000"
"y_0=3D0.000000"
"ellps=3Dsphere"
END
LAYER
NAME "img2000"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "raster mosaic"
"wms_server_version" "1.1.0"
"wms_formatlist" "image/png,image/jpeg"
"wms_format" "image/jpeg"=20=20=20
END
END=20=20
The re-pojection for the WMS layer seems to work not fully properly. I att=
ached 2 files. The one called 'smallscale.jpg' is a clipped part of the or=
iginal image where Italy is located more to the bottom right of the origin=
al map and there is a big difference between the WMS layer (being composed=
from satellite images) and a shape file (transparent and in the Lambert p=
rojection). If I zoom closer in and center the Southern part of Italy on t=
he map then there is still a noticeable difference between the two layers =
but the distortion is much lower. This is visible in the attached file 'me=
diumscale.jpg' (clipped part of full image).
The re-projection works very fine for another static image layer in EPSG:4=
326 and re-projecting it to the Lambert system of the MAP.=20
Can anybody give me a hint why this problem may appear for WMS layers?
Thanks for any help,
Armin
--AKMAILBOUNDARY
Content-Type: application/octet-stream; name="smallscale.jpg"
Content-Transfer-Encoding: base64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--AKMAILBOUNDARY
Content-Type: application/octet-stream; name="mediumscale.jpg"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--AKMAILBOUNDARY--
