[Mapserver-users] Trouble using Perl newClass->setText( $newLayer, "hello" )
Lowell Filak lfilak at medinaco.org
Thu Feb 12 16:35:35 EST 2004
I don't know how far it will go but, do you have logging turned on and
is there anything in the log?
I noticed that there is an msResetErrorList() in mapfile.c under the
loadExpressionString function that is used to load the string value into
the classObj but I don't see anything printed if it segfaults in the
function.?
Also, did you already check to see if it is segfaulting on the
$newClass->{label} = ... for some reason after the text is set?
Lowell
The following message was sent by "PATTERSON KENNETH ALLEN"
<kapatter at srpnet.com> on Wed, 11 Feb 2004 17:01:43 -0700.
> I am creating a layer on the fly with one class.  I am able to create
the map successfully w/out using setText().  The symbols in the layer
shows up fine.  As soon as I call  $newClass->setText( $newLayer,
"hello" ) to display a field/value it segfaults.  My code snippet is
below.  Can anyone advise what I am doing wrong?
> Thanks,
> 	Ken
> # ------------------------------------------- CreateALayer
> sub CreateALayer {
> 	my ($msObj, $shapeFName) = @_;
> 	if ($msObj && $shapeFName) {
> 		my $newLayer = new mapscript::layerObj( $msObj );
> 		if ($newLayer) {
> 			print "\t\tNew Layer $newLayer created, setting values.\n";
> 			$newLayer->{name} = "WindData";
> 			$newLayer->{group} = "Dynamic Layer";
> 			$newLayer->{template} = "dummy-template-name";
> 			$newLayer->{status} = $mapscript::MS_ON;
> 			$newLayer->{data} = $shapeFName;
> 			$newLayer->{type} = $mapscript::MS_POINT;
> 			my $newClass = new mapscript::classObj( $newLayer );
> 			if ($newClass) {
> 				print "\t\tCreated Class object $newClass, setting values\n";
> 				$newClass->{name} = "Wind Gust";
> 				$newClass->{status} = $mapscript::MS_ON;
> 				$newClass->setExpression( "(\"[WGUST]\" ne \"\")" );
> 				$newClass->{color} = $msObj->addColor( 255, 0, 0 );
> 				$newClass->{symbol} = 1;
> 				$newClass->{minscale} = 100;
> 				$newClass->{maxscale} = 800000;
> 				$newClass->{size} = 8;
> 				$newClass->setText( $newLayer, "([WGUST])" ); # This causes a
segfault!
> 				$newClass->{label} = new mapscript::labelObj();
> 				if ($newClass->{label}) {
> 					print "\t\tNew Lable object $newClass->{label} created!\n";
> 					$newClass->{label}->{backgroundcolor} = $msObj->addColor( 80, 80,
80 );
> 					$newClass->{label}->{color} = $msObj->addColor( 255, 200, 0 );
> 					$newClass->{label}->{size} = 8;
> 					$nwsClass->{label}->{type} = $mapscript::MS_TRUETYPE;
> 					$nwsClass->{label}->{font} = "helmetBI";
> 					$nwsClass->{label}->{position} = $mapscript::MS_AUTO;
> 					$nwsClass->{label}->{partials} = $mapscript::MS_FALSE;
> 					$nwsClass->{label}->{minsize} = 6;
> 					$nwsClass->{label}->{maxsize} = 12;
> 				} else {
> 					print "\t\tError: Unable to create lable object!\n";
> 					return( 0 );
> 				return( 1 );
> 			} else {
> 				print "\t\tError: Unable to create class object!\n";
> 				return( 0 );
> 		} else {
> 			print "\t\tError: Unable to create layer object!\n";
> 			return( 0 );
> 	return( 0 );
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
