[Mapserver-users] Chaning output projection on request.
Martin Weinelt
mweinelt at planiglobe.com
Fri Feb 13 04:01:36 EST 2004
On Friday 13 February 2004 02:17, Jason M. Nielsen wrote:
> Anyone have an example of how one can set it up so a user can select a
> different projection from a list as the display projection (main output)?
> I was almost thinking one would have to have a .map file for each
> projection in which the only change was the EXTENT and and Projection
> definitions.
> I was rumaging through the dbox code on how one might submit a new extent
> and projection but didnt see anything.
> Thanks.
Jason,
I do it with separate .map-files (and projected data) for each projection. The
interface has a <FORM> that provides projection selection:
<form name="proj_form" action="">
<select size="1" name="Auswahl" onChange="setProj()" width="150">
<option value="DD.map">Kartesian</option>
<option value="ME.map">Mercator</option>
<option value="LN.map">Lambert Azimuthal North</option>
<option value="LS.map">Lambert Azimuthal South</option>
</select>
</form>
This above form calls a js function ("setProj()"):
function setProj(theMap) {
var myForm = document.forms['map_form'];
var projForm = document.forms['proj_form'];
var mapFileName =
projForm.Auswahl.options[projForm.Auswahl.selectedIndex].value;
// set the corresponding mapfile
var mapFile = docRoot + mapFileName; // docRoot has the path
myForm.map.value = mapFile;
// set the mapextent to initial big map
switch (mapFileName) {
case "DD.map":
myForm.mapext.value = "-180 -90 180 90";
// change corresp. ref-image here
break;
case "ME.map":
myForm.mapext.value = "-20000000 -20000000 20000000 20000000";
break;
case "LN.map":
myForm.mapext.value = "-7000000 -7000000 7000000 7000000";
break;
case "LS.map":
break;
myForm.mode.value = "browse";
myForm.submit();
That works for me ...
Cheers, Martin
