[Mapserver-users] Max number of layers craps out at about 295
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 13 10:44:42 EST 2004
Stephen Clark wrote:
> Pericles,
> I chose the number 700 for each of the following :
> #define MS_MAXCOLORS 700
> #define MS_MAXCLASSES 700
> #define MS_MAXLAYERS 700
> because I thought that each LAYER needed the same number of CLASSES and
> COLORS.
> So can I assume that if I have about 3 classes per layer then I can use the
> following:
> #define MS_MAXCOLORS 128
> #define MS_MAXCLASSES 128
> or perhaps a number less than 128?
> I will try out this option and recompile MS with the above specs.
Stephen,
MAXLAYERS and MAXCOLORS should be pretty configurable. But I would like
to discourage using values for MAXCOLORS other than 256 unless you have
looked through the implications. Somethings are just #defined macros out
of habit ... not because they should be fiddled with.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
