[Mapserver-users] Re: question about JBox
Richard Greenwood rich at greenwoodmap.com
Fri Feb 13 10:47:26 EST 2004
Kristjan Annus wrote:
> Hello
> I find your address from mapservers JBox contributors list.
> I hope you don't mind if I ask one question from you.
> Is it possible to get SetImage method work under Netscape or
> Mozilla. Every time when I try it I'll get some kind on Java
> security error?
> best wishes
> Kristjan Annus
I do not use the setimgae() function and so I do not have a quick way to
test it. I looked at the Java code, and I can not see any difference
between the way that setimage() requests the image, and the way that
that the image is requested my the initialization code (the mode that I
use in my applications).
Do you receive the security error only with setimage() and not with a
"standard" invocation of jBox e.g.
             <applet
                   codebase="/java/jBox"
                   archive="jBox.jar"
                   code="jBox.class"
                   width="600"
                   height="600"
                   name="jBox"
                   MAYSCRIPT>
               <param name="image" value="http://[host][img]">
             </applet>
Richard Greenwood
www.greenwoodmap.com
