[Mapserver-users] concatenate 2 or more fields inshapefile to display in MS as label
Stephen Clark
stephen.clark at focus.ca
Fri Feb 13 15:58:51 EST 2004
Steve,
When I use the WRAP as indicated below, I get the following error:
loadClass(): Unknown identifier. Parsing error near (WRAP):(line 1249)
thanks
Stephen
----- Original Message -----
To: <stephen.clark at focus.ca>; <mapserver-users at lists.gis.umn.edu>
Sent: Friday, February 13, 2004 11:27 AM
Subject: Re: [Mapserver-users] concatenate 2 or more fields inshapefile to
> You have to define a WRAP character, and then place that character in
> your string. So, to break the sting after the township id you'd do
> something like:
> WRAP '_'
> TEXT (TWP [TWP]_RNG [RNG])
> Steve
> >>> "Stephen Clark" <stephen.clark at focus.ca> 2/13/2004 1:35:43 PM >>>
> Steve and others,
> I am able to get two or more fields concatenated as follows:
> TEXT (TWP [TWP] RNG [RNG])
> but would like the output to be displayed down the screen instead of
> across.
> How would I insert a Newline Character in this text string?
> thanks,
> Stephen
> From: "Steve Lime" <steve.lime at dnr.state.mn.us>
> Sent: Wednesday, February 11, 2004 1:16 PM
> shapefile to
> > Use the TEXT option in the class object. You'd do something like:
> > TEXT "TWP [TWP] RNG [RNG]"
> > You could do the concatenation ahead of time in ArcView or any other
> > software (e.g. perl with XBase.pm) that could manipulate dbase
> files.
> > Steve
> > >>> "Stephen Clark" <stephen.clark at focus.ca> 2/11/2004 3:56:12 PM
> > Hi all,
> > I have two fields in a Shape file that I would like to Concatenate
> and
> > display as a label in mapserver.
> > For example:
> > LAYER
> > NAME township_range
> > TYPE LINE
> > STATUS OFF
> > DATA "d:/shp/townships"
> > LABELITEM "TWP"
> > # and I want to concatenate
> > # LABELITEM "RNG"
> > # to the label
> > CLASS
> > COLOR 10 10 10
> > LABEL
> > MINFEATURESIZE 40
> > MINDISTANCE 150
> > POSITION AUTO
> > COLOR 10 10 10
> > FONT arial
> > TYPE truetype
> > SIZE 10
> > FORCE TRUE
> > END
> > END
> > END
> > I would like the final string to be like "084 021" .
> > OR a more general case
> > 'TWP' + 'township value' + 'space' + 'RNG' + Range Value'
> > like:
> > "TWP 084 RNG 021"
> > Has anyone tried this out?
> > thanks
> > Stephen
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
